Backspin, here 🙂
Old Jun 30, 2022 | 01:36 AM
Backspin's Avatar
Backspin, here 🙂
Hi can anyone tell me if my 88 GTA Firebird has a starter or solinoid relay and if so where is it, i am told by a Pontiac guy i does not have a starter relay?
Would appreciate any help, Thanks.
Old Jun 30, 2022 | 09:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Backspin, here 🙂
If you have a chip in your ignition key it has a starter enable relay under the drivers side kick panel.
Old Jun 30, 2022 | 07:19 PM
Backspin's Avatar
Thanks for that.
I partially removed the kick plate but cant see too much.
Where could i get one or see a picture of one?
The Ponti dealer in Australia here still says they dont have one?
Thanks so much for your help.
Old Jun 30, 2022 | 07:35 PM
Engine: Lb9
Transmission: M20
or bypass
Old Jun 30, 2022 | 09:08 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Is there a chip deal on your ignition key? Or just a standard key? The passkey module is on the passenger side up in the dash, hard to see and hard to get to. What is the actual problem here?
Old Jun 30, 2022 | 09:32 PM
Backspin's Avatar
Originally Posted by Backspin
Thanks for that.
Thanks could be the relay behind the kick plate or the unit that stops starting when in gear, which is under the console.
How do i remove the console?
Old Jun 30, 2022 | 09:48 PM
Backspin's Avatar
Also when i removed the starter there was no gaskets between the exhaust pipes and the manifold so i put some high temp gasket cement when i re installed the starter.
is this correct?
Old Jul 3, 2022 | 02:41 AM
Backspin's Avatar
The local Ponti guy here said if i have a chip in the key, which it does , then its a 1989, not 88.
I removed the kickplate and found a small metal component with 2 plugs coming out?
What you think and can anyone post a pic jf they have similar?
Thanks so much.
Old Jul 3, 2022 | 10:10 AM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tech...-did-they.html
Old Jul 3, 2022 | 04:54 PM
Backspin's Avatar
Sounds like its the starter enable relay.
Where can i get one?
Thanks to all for your help.
Old Jul 3, 2022 | 05:40 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
If the engine is having a tenancy to 'backspin' during cranking it could be wayyy out of timing adjustment
Old Jul 5, 2022 | 07:00 PM
Backspin's Avatar
Can anyone send me the GM part no for the Starter Enable Relay., this seems to be what i need.
Thanks so much.
Old Jul 5, 2022 | 07:42 PM
Engine: Lb9
Transmission: M20
Thanks so much.
that was covered in post 4 it’s nla
Old Jul 8, 2022 | 06:12 PM
Backspin's Avatar
Hi there ,
Thanks for that but i need the part no as i m not in USA.
Would appreciate where to get it or a contact?
Thanks.
Old Jul 8, 2022 | 06:38 PM
Engine: Lb9
Transmission: M20
Nla , just bypass or post in classified section wanted good used. Or rewire to spdt relay and plug.
Old Jul 11, 2022 | 02:03 AM
Backspin's Avatar
It looks like the starter relay will have to by passed.
Will this be ok and not cause any other damage?
Thanks so much guys for your help.
Old Jul 11, 2022 | 07:27 PM
Backspin's Avatar
I am told could be the anti theft relay
Can anyone tell me where this is located?
Again thanks so much for your help.
Old Jul 11, 2022 | 07:55 PM
Engine: Lb9
Transmission: M20
same thing
Jcase350
May 5, 2011 03:10 PM
bluegoose
Nov 6, 2009 09:53 PM
FirebirdBrtha90
May 10, 2009 11:05 AM
