What year did they start using VATS modules and "chipped "keys??
Old Mar 14, 2021 | 08:40 PM
Transamcrazy98's Avatar
Car: 1987 Trans Am GTA x2
I have an 87 gta that has a chipped key. I just got it and am trying to get it to run. Engine turns over but sounds like it's not even trying to fire. Hence VATS VATS question. I have another earlier build 87 that has a normal key. Thanks for any help and advice .
Old Mar 14, 2021 | 08:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What year did they start using VATS modules and "chipped "keys??
In f-body late 88 , y 86
Old Mar 14, 2021 | 08:45 PM
Engine: Lb9
Transmission: M20
Look at the ecm pin b6 if there is s blue wire or list the letters on the chip I can see if I have the binary to check if it has vats. Possibly someone put in a new column. Vats started in y body 86 f body late 88.
Old Mar 14, 2021 | 09:39 PM
Okay I will check tomorrow and let you know what got.
Old Mar 15, 2021 | 03:54 PM
GeneralDisorder's Avatar
VATS disables the starter also. So unlikely to be your problem.
GD
Old Mar 15, 2021 | 04:11 PM
Engine: Lb9
Transmission: M20
I’ve seen the passkey module produce less than expected lately and the enable relay still get grounded.
odd its a 87 with chip key but could be a column swap.
Old Mar 15, 2021 | 06:55 PM
JT's Avatar
JT
Community Administrator
The VATS first appeared on the GTA for those built in December of 1987 for the 1988 model year. So early 1988 GTAs did not get the VATS. Records show 2/3s of 1988 GTAs got the VATS so you're likely to see it more than not on a 1988 GTA. Don't know of any that got it earlier. If you have the SPID/RPO sticker, let us know.
From our friends at GTASourcepage:
Old Mar 15, 2021 | 07:29 PM
Engine: Lb9
Transmission: M20
Very interesting, I looked at for example chip code AKXZ listed for 88 305 tpi automatic.
was released on 05/19/87 and has vats enabled.
graysmoke
Mar 10, 2014 03:31 PM
kreator33
Oct 27, 2011 05:58 PM
affliction1
Jun 29, 2010 11:34 AM
J's25thZ28!
Mar 14, 2003 01:42 PM
Zuckuss88GTA
Jun 17, 2002 10:39 PM
