How's the ZZ-4 cam with a carb?
Old Feb 24, 2019 | 11:36 AM
ironhead88's Avatar
I'm having thoughts of buying a ZZ-4 cam #10185071
With 208 deg of intake @ .050"
Anyone out there using that?
Old Feb 24, 2019 | 11:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How's the ZZ-4 cam with a carb?
The zz4 was a carbed crate engine .
Old Feb 24, 2019 | 01:03 PM
Exactly... that cam was MEANT to go along with a Holley 4-bbl.
Old Feb 24, 2019 | 03:58 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I used in my 383 on a 87 and it passed the dyno emissions when it was tested sounded stock IMO
Old Feb 24, 2019 | 04:37 PM
Yup, it probably would sound basically stock, in a 383. It'd be more likely to be noticeable in a 350 but still only just barely.
Old Feb 25, 2019 | 10:28 AM
ironhead88's Avatar
I see - I thought that the ZZ-4 was an LT-1 option
I was thinking LT-4, I guess
Sounds good though - This will be going into a 327 with retrofit hyd roller system.
About 9:1 CR Iron heads
Old Feb 25, 2019 | 10:46 AM
The ZZ4 is not particularly related to the LT1. (or for that matter, "LT-1", whatever that might be...) It was a crate motor sold over the counter starting in the late 80s or early 90s (sorry, can't recall when the ZZ3 was replaced by the ZZ4) by GM at stealerships and other outlets like Summit, consisting of a L98 short block (638 block originally then later 880, a 350 w/ very slight dish pistons) and 113 heads (aluminum, 58ish cc, the same ones used on the Vette version of the L98), with an Edelbrock Performer intake that had a bowtie cast into it in place of the "Edlebrock" logo. And of course, that cam. The ideal carb for it, in my personal experience, was the Holley 6210.
In fact, it was sold as part of a "kit" upgrade for the L69, which included a chip and some E4ME calibration parts tailored for it and some other things specific to the L69. It was at least 49-state legal in that trim, maybe even 50-state.
Yes of course you will definitely need the retrofit hyd roller system in any actual 327. Although if the way you went about it was to downgrade a later-model 350 short block to fewer CID, it's entirely possible that you could build the lesser, lower-output motor that could use the factory roller system, although to create this downgraded setup would cost more than building it for the full potential of the original ZZ4 at 350 CID. Wouldn't be a very sensible thing to do even though "possible". Like so many things, "possible" does not necessarily translate automatically to "A Good Idea".
Old Feb 25, 2019 | 11:01 AM
Engine: Lb9
Transmission: M20
As part of a retrofit, you need a retrofit cam and cam button.
Old Feb 25, 2019 | 11:05 AM
The ZZ4 cam can be used with the "retrofit" (some of us prefer to think of it as the "original" ) roller system, but you have to use a nylon cam button, and carve it down to fit within the smaller bolt circle on the front of the cam. You also have to use a factory-roller cam sprocket and some sort of spacer to take up the thickness of the factory roller cam retainer plate, which can be as simple as taking an actual retainer plate and grinding off the "ears" where the bolt holes are.
Yes; BTDT.
Old Feb 25, 2019 | 11:14 AM
Engine: Lb9
Transmission: M20
I was unaware of that and thought the cam length was different. Because the zz4 uses a retainer to keep it from walking. What timing chain would one use. One for a roller cam with retainer or a older chain.
Old Feb 25, 2019 | 11:26 AM
AFAIK the chains themselves are the same within a given brand, but to be safe, the smart thing to do would be to buy it as a full set. You'd need the factory-roller timing set.
The cam length is the same, because the block length is the same. That's why you can freely install a flat-tappet cam into a roller block, just like GM themselves did in many short blocks such as L05 (same 638 or 880 casting as the ZZ4 & L98). Everything is the same, at that level. The thing that's different, in addition to the cam bolt pattern, is the back side of the cam sprocket. The roller sprocket is .050", or whatever it is, thinner. The thickness of the retainer plate which I can't recall off the top of my head.
The roller bolt pattern is smaller because the retainer plate extends into the radius of the cam journal about 1/8" or so. The bolts in the older-style bolt pattern would interfere with the roller retainer plate. Then since the bolts are so much closer together, the usual cam buttons such as the fully roller ones won't fit down among them. That's why you have to use the nylon type and carve it down. You can take a cylindrical grinder and make 3 appropriate divots in the nylon quite easily.
Old Feb 25, 2019 | 11:28 AM
Engine: Lb9
Transmission: M20
Gotcha, great information
ironhead88's Avatar
It's Impossible to explain using words. It seems to make things more confusing.
But if you have the actual part in hand you can see that there is some swap-ability.
A new timing gear with a smaller diameter front is needed
Old Feb 25, 2019 | 11:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
thats the stepped nose design that allows the retainer plate to fit. Non oem roller cams dont have that and use a button. For a stepped nose cam in a non roller block guys seem to drill tap the front to allow the oem retainer plate installed and just cut off the tabs that over hang. Eliminates buttons
http://garage.grumpysperformance.com...y-block.14182/
Old Feb 25, 2019 | 12:20 PM
ironhead88's Avatar
I get what you're saying.
I have a storage area that has an assortment of old parts... All Chevy small block
Including a 327 balanced assembly that I could put into a roller block with an adapter which is also sitting there on one of my shelves
Or I could put that balanced crank assembly into a 4 bolt block and use some retrofit roller lifters that I know are in one of those boxes somewhere.
I wouldn't buy new parts and do that, but it ought to be OK for a car that I commute in that will hopefully burn 87 octane gas and get good MPG as well
Thanks for the info
Old Feb 25, 2019 | 12:59 PM
Engine: Lb9
Transmission: M20
Hers a good price for some retrofit lifters
https://www.thirdgen.org/forums/engi...clean-out.html
Old Feb 25, 2019 | 03:56 PM
Yup, you can sometimes drill and tap the block, but not all have a smooth machined place where the bolt holes need to be. Sometimes it's as-cast. Esp older blocks.
Old Mar 15, 2021 | 10:50 PM
ken5's Avatar
Car: 1992 Chevy Camaro RS
Engine: L31 Vortech
Transmission: 4l60
Axle/Gears: 3.08
Here are some specs. For future F-Body DIY. Better late than never.
File Type: pdf
camaro350tpi
Apr 2, 2010 01:02 PM
tpivette89
May 29, 2003 11:52 AM
D's89IROCZ
Jan 30, 2003 06:56 PM
92zeddar
Jul 3, 2002 02:55 PM
JR4444
Feb 4, 2002 09:38 AM
