1227747 ECM
Old Oct 18, 2022 | 06:51 PM
DanBrown's Avatar
Car: Currently a 2010 Ford Edge
Engine: 3.5 L V6
Transmission: Automatic
Axle/Gears: Ukn
1227747 ECM
I'm currently trying to wire a 1227747 ECM in my pickup. I'm trying to get the check engine light to come on per the wiring diagram. It say to wire one side of the bulb to a switched 12 v score and the other to pin A5 at the ECM, which grounds the system inside the ECM. I've done all this and checked and double checked the whole system, and the light won't come on. Is this an indication that something inside the ECM is bad or could it be something else?
Old Oct 18, 2022 | 07:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1227747 ECM
Have you verified the ecm is powered up with constant and switched power ?
Old Oct 18, 2022 | 07:20 PM
DanBrown's Avatar
Engine: 3.5 L V6
Axle/Gears: Ukn
Re: 1227747 ECM
Yes, both A6 (12v switched) and B1 (12v all time) are good.
Old Oct 18, 2022 | 07:23 PM
Engine: Lb9
Transmission: M20
Re: 1227747 ECM
C16 ?
Old Oct 18, 2022 | 07:29 PM
DanBrown's Avatar
Engine: 3.5 L V6
Axle/Gears: Ukn
Re: 1227747 ECM
You are correct, C16 also. Not sure I have that one hooked up. If not, would that cause the MIL not to come on. Hope it's that simple.
Old Oct 18, 2022 | 08:03 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 1227747 ECM
Does the bulb light if you give it power and a test ground?
Old Oct 18, 2022 | 08:13 PM
Engine: Lb9
Transmission: M20
Re: 1227747 ECM
yes
Old Oct 19, 2022 | 08:00 AM
DanBrown's Avatar
Engine: 3.5 L V6
Axle/Gears: Ukn
Re: 1227747 ECM
Something else I noticed on my 1227747 schematic is that for 5L and 5.7L engine, the 5.7 being what I have, it shows the brown/white wire at A5 with a spliced wire going to pin D on the ALDL. Not sure I under stand the meaning of this wire, but on a 1227747 schematic for the 2.8L and 4.3L it doesn't show this spliced wire. Anybody know what's up with that spliced wire, and why that might keep the check engine light from coming on?
MrMathers
Apr 20, 2021 08:17 AM
Mystyk_Wynds
Jan 31, 2013 08:32 PM
garyspinco
Nov 7, 2011 08:58 AM
400Z28Racer
May 17, 2003 10:49 AM
