Headlight upgrade problem
Old Feb 4, 2023 | 08:36 PM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
Anyone done the headlight upgrade and have issues with them not dimming ? I done it and built a new harness but cannot get them to dim without pushing my light switch back to parking lights then back to headlight on. I have replaced the headlight switch and dimmer switch with no difference. It acts as though I am getting a back feed. This is the diagram I used.
Old Feb 18, 2023 | 05:59 PM
RJ 1's Avatar
Car: 86 Iroc
Engine: 421
Transmission: th400
Axle/Gears: 3:73
Re: Headlight upgrade problem
I just wanted to follow up and say I resolved my issue. I woke up the other night at 2a.m and it came to me I wasn’t feeding my headlights through the factory switch and wiring anymore since doing the upgrade. After doing some digging and tracing wires I realized I was feeding both sides of my coil in the fog light relay, one side off the headlight/parking light signal and the other side off of the high beam signal. I just unpinned the high beam signal and added a ground to that pin on the relay. I know have working headlights and fog/driving lights. I also like that my fog/driving lights will operate with both high and low beams/parking lights.
Hopefully this will help someone else.
lilking53
Nov 10, 2017 10:12 AM
dairishman85
Feb 12, 2013 02:43 PM
1 Quick T/A
Jan 27, 2009 06:05 AM
