Help with relay
Old Feb 7, 2023 | 07:57 PM
83HOZ28's Avatar
Car: 1983 Z28
Engine: 5.0 HO
Transmission: 5 speed
Axle/Gears: don't know
Help with relay
Can anyone tell me what this relay is for? There's a couple of wires that have been chewed on and I'm trying to see what they are for. The one wire is brown with white stripe and the other one is black. My car is a 83 Z28 H.O with the 5 speed. Thank you for your time!
Old Feb 7, 2023 | 08:07 PM
Re: Help with relay
Wish I could remember which relay is which in my 83 L69 T-5 car... butt you know what I heard that They say: your memory is the 2nd thing you're supposed to lose as you get old, I just can't remember what the 1st one was...
Anyway, post the colors of all the wires, and we can more probably tell you. Although, the next one is the MAP sensor and the one nearest the fender, not in that pic, is the fan relay, if I can trust my last 2 brain cells (that I'm busy killing right now).
Old Feb 12, 2023 | 08:35 PM
83HOZ28's Avatar
Car: 1983 Z28
Engine: 5.0 HO
Re: Help with relay
Here are a couple of pictures of the relays. I'm trying to figure out which one is for the cooling fan.
Old Feb 21, 2023 | 02:43 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Help with relay
Is the 83 HO a carb or cross fire injection car? when you untwist those two wires what doesn't work?
Old Feb 21, 2023 | 03:38 PM
vorteciroc's Avatar
Top Answer: 1
Re: Help with relay
The Electric Cooling Fan will have a Fusible-Link going into the Connector.
I do not think I see a Fusible-Link in the Image.
Any Relays on the Radiator Support side?
Old Feb 21, 2023 | 04:02 PM
83HOZ28's Avatar
Car: 1983 Z28
Engine: 5.0 HO
Re: Help with relay
My car is carbed. The relay for the cooling fan is the middle one. But when I twist the two black wires together sometimes the car won't start. It just turns over.
There are no relays next to the radiator. If I jumper the red and black wires in the relay harness the fan will come on.
Old Feb 23, 2023 | 08:29 PM
83HOZ28's Avatar
Car: 1983 Z28
Engine: 5.0 HO
Re: Help with relay
I got it all figured out! The relay that I had bought was defective. I replaced it and the A/C fuse under the dash and everything is working the way it should. Fan comes on at about 225/230 on it's own. Fan also comes on when the A/C is switched on. Now to tackle all of the other things that needs to be done.
Old Feb 24, 2023 | 01:30 AM
vorteciroc's Avatar
Top Answer: 1
Re: Help with relay
If you have any issues with that style Relay or Connector in the future...
Here are the Parts that GM used as an Update:
Sealed style Metri-Pack 630/ 280 Relay.
Now discontinued by GM, but available in the Aftermarket: Standard Motors part #RY109.
The corresponding Pigtail.
Still available from GM: ACDelco part #PT1115.
RockAuto.com usually has good prices on these...
Also there are usually Discount Codes Posted in the "Aftermarket Vendor Review" Sub-Forum.
Old Feb 24, 2023 | 02:11 AM
83HOZ28's Avatar
Car: 1983 Z28
Engine: 5.0 HO
Re: Help with relay
Thank you for the information!
Old Feb 24, 2023 | 02:48 AM
vorteciroc's Avatar
Top Answer: 1
Re: Help with relay
You are most welcome!
BlueWrath92
Jul 20, 2010 11:12 PM
MI ROC-Z
May 30, 2009 06:16 PM
Chaotic Neutral
Feb 17, 2009 09:20 AM
Randy82WS7
Jun 9, 2003 11:08 AM
Quiet Bob
Apr 9, 2001 09:52 PM
