VSS Buffer
Old Jan 21, 2002 | 10:20 AM
Turbo Bob's Avatar
VSS Buffer
Got a 91 Camaro RS 305 TBI E code motor with 700R4 trans. My problem is the ECM is throwing a code 24 VSS sensor. Replaced the vss sensor on the driver's side tail shaft of the trans. Same problem as before. Code 24 and speedo inop and cruise control inop. Looking for vss buffer in the car. Where is it located in my car?
Old Jan 21, 2002 | 02:33 PM
Brent's Avatar
The buffer is under the passenger side dash next to the ECM. Its a little yellow box.
Old Jan 21, 2002 | 07:18 PM
Turbo Bob's Avatar
VSS Buffer
Brent,
Thanks for the info. How do you check the vss buffer to see if it is bad?
Old Jan 22, 2002 | 12:50 PM
Brent's Avatar
Sorry, I don't know. There is probably a procedure in the Helm manual.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
