LED headlight upgrade. Digi dash problem
Old Apr 15, 2023 | 07:42 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
Have an 88 gta with digital dash. Installed LED headlights from screaming chicken. My drivers information center (DIC) now displays I have headlight issues. Also my left turn signals no longer work. Right signals work. How can i fix this issue?
Old Apr 17, 2023 | 09:35 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: LED headlight upgrade. Digi dash problem
https://www.thirdgen.org/forums/auto...ml#post6406433
Old Jul 23, 2024 | 12:16 PM
Edward748's Avatar
Car: 1988 GTA
Transmission: Manual
The same message came on for me recently after upgrading to led headlights.
Old Jul 23, 2024 | 07:59 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You apparently have headlights with "Lamp Monitor". Functional description is on page 1463 of the 88 Firebird service manual, https://www.thirdgen.org/forums/tech...ce-manual.html
There is a comparator circuit that checks the headlights and a message will appear in the DTC if doesn't pass that comparison. I think maybe it compares current, so a circuit resistance imbalance between headlight bulbs would maybe cause the fault warning to appear.
Old Jul 24, 2024 | 07:48 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Screaming chicken sent me resistors for the headlights. That seem to work. occasionally the " F lamp" message would pop up on the DIC. But, after I upgraded the positive and negative wires on the battery and to the engine and frame, I have not received that message. I didn't do the "big 3" upgrade because of this issue. did it because bigger stereo, bigger alternator, fans etc. but since that seemed to fix it, sounds like i possibly had a bad ground somewhere. Now the DIC says PONTIAC like its supposed to do when there isn't a problem.
Sparten2068
Sep 3, 2020 01:26 PM
GTA1990
Mar 3, 2011 05:48 PM
Zrated83
Oct 25, 2005 06:04 PM
DiecastZ28
Sep 10, 2003 12:09 PM
Krush 32
Apr 9, 2002 09:22 AM
