Power button for radio
Old Apr 20, 2023 | 09:29 PM
stoutblock's Avatar
Car: 1989 IROC-Z coupe LB9 T5 G92 N10
Engine: LB9 with L98 cam
Axle/Gears: 9 bolt 3:45 (G92 G80)
My radio works fine but always stays on when key is on and the power button has no effect. Based on research here this appears to be a common problem but no real specifics on how to repair. I assume I find a donor unit to steal a button from?
Old Apr 21, 2023 | 10:20 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Power button for radio
For the cost of another usable unit you could send yours off to have it repaired? I had a factory cassette deck repaired and had a AUX cable installed for a very reasonable price.
Old Apr 21, 2023 | 10:58 AM
stoutblock's Avatar
Do you have a repair service recommendation?
Old Apr 21, 2023 | 11:07 AM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
M&R Electronics Inc.
5665 State St.
Saginaw, MI. 48603
U.S.A.
Call us at 1-800-343-1382
Old Apr 21, 2023 | 11:12 AM
91banditt2's Avatar
Engine: 5.7 HSR
A fellow named Anthony Barlos that goes by Barlosal, I don't know/don't think he's a member here, I came across him searching online for someone to repair and upgrade my factory unit, he came highly recommended from some of the G-Body forums if I remember correctly. Don't take my word for it search online for his name. He was pretty quick also, he had mine done in 2 days ready to be shipped back to me repaired and with a 4 foot long AUX cable which I ran into my center console.
barlosal@aol.com
Old Apr 22, 2023 | 12:41 AM
stoutblock's Avatar
Thanks guys, very helpful.
I did find out I may have some other problems with this radio unit. The right rear channels is not working (right front works fine). I checked the speaker (10 ohm by the way) and it works fine so it is ether the head unit or the wires to the speaker. Also the radio reception could be better.
The Cassette player itself seems to work fine (not counting the right rear channel).
I found this site which is very helpful:
http://www.howtoalmanac.com/Scott/Ho...oAmpRepair.htm
As one of my other hobbies is restoring old audio equipment I might start by taking a look inside. Maybe this is something I can fix myself. Granted it might be smart to pay someone else that has already screwed up enough to learn how to do it right?
Old Apr 22, 2023 | 12:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'm sure I can help out,........ A bad power button is pretty common and the dead speaker channel is almost certainly a capacitor problem. I might be able to supply you with a restored 'core' for about the same cost as getting the original radio repaired ---> depending on the radio you've got. Can you post a pic of your radio ?? What year is your ride ?? Want an AUX connection ? Maybe bluetooth ?
Old Apr 24, 2023 | 06:36 PM
stoutblock's Avatar
I pulled my deck today to check things out. It is exceptionally clean inside and out. No sign of any leaking caps etc. I realized the power switch was hot wired on. I re-soldered it correctly and thinking this probably means the switch does not work but was surprised it works fine. Hmmm?
The tuner did not work that well and realized the antenna cable was not well connected. Channels come in much stronger now.
Still don’t have the right rear speaker working so probably look into that further. If I can’t figure it out I will reach out to you on giving it some attention.
Old Apr 26, 2023 | 11:51 AM
John in RI's Avatar
The speakers issue will almost certainly be the Capacitors,..... if you replace the Caps and the channel still doesn't work,.. it's probably an AMP chip. This is what I mean by a restored core,...... just re-use your original faceplate ( and cassette mech too maybe ) to help keep replacement costs down,... + your only paying to ship 1-way. Pretty sure I've got "rebuilt" ( meaning all repairs + new Caps ) and "restored" ( meaning all repairs EXCEPT for new Caps ) available depending on the type of radio you have/need.
I can also add a corded AUX or Bluetooth ( to most radios ).
Old May 25, 2023 | 12:42 AM
stoutblock's Avatar
I ended up getting a rebuilt deck from John and it works great! Also has an aux jack for my iPod. My IROC is a rockin!
kentuckyKITT
Car Audio
Jun 10, 2020 03:53 PM
Hawkeye1980
Car Audio
Mar 16, 2014 06:46 PM
kylet8020
Car Audio
Sep 11, 2012 06:54 PM
cc 82Z-28
Car Audio
Nov 22, 2009 07:41 PM
ssjflint
Car Audio
May 13, 2006 08:44 PM
