stock stereo blues
Old Sep 11, 2012 | 01:55 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
stock stereo blues
I've been hitting up the local junk yards for last 2 weeks and I came across a 87 Camaro with the stock basil and radio. so I grabbed everything that I was looking for off the vehicle and took the radio home the previous owner had ripped up the wiring for the radio so I grab that too. after soldering up all the connections and shrink taping them I plugged in the radio and to my surprise it came on. the power button did not work properly so I did some research and found that I can jump the pink wire for the power antenna. the radio work but it will only stay on for 3 to 5 seconds before shutting off. I have to hit the volume button to turn it back on it keeps time so I know it's not losing power. I've done some research and I'm going to fix the power button properly is there a way to fix the radio totally or is it junk.
Old Sep 11, 2012 | 06:54 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: stock stereo blues
Sounds like you just need to replace the power button. The pink wire is just a back feed.
z28_AJ
Aug 27, 2015 08:59 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 8, 2015 01:18 AM
