1984 TRans AM - fuse boxes
Old May 15, 2023 | 10:49 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
I am familiar with the fuse box under the driver's side dash. Is there 2nd fuse box in the car & where?
Old May 15, 2023 | 11:03 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: 1984 TRans AM - fuse boxes
No fuses anywhere else. Not the same, but there are some fusible links. I think there's one near the starter / battery and another for the headlights somewhere.
Old May 15, 2023 | 11:48 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The only other place there could be fuses is if the car has had any of the vapor lock TSBs installed that added an in-tank pusher fuel
pump and carb bowl cooling fan. There will be some rubber molded inline glass fuse holders near the red high speed blower fan power
wire in the engine compartment. The TSB wiring harnesses tap into that circuit for power.
Old May 16, 2023 | 04:57 AM
OrangeBird's Avatar
Car: 1989 Firebird
There is also the so called "convenience center" , if that was even a thing in 1984 ? I know later cars (like my 1989) have it, but I'm not sure if the earlier cars did.....
Old May 16, 2023 | 05:10 AM
OrangeBird's Avatar
Car: 1989 Firebird
Also, all of the cars with an ECM have a stand alone fuse here ;
Old May 16, 2023 | 07:00 AM
battmann's Avatar
hey - i learned something today! never knew about that fuse.
Old May 16, 2023 | 07:08 AM
The carbed cars didn't have the external ECM fuse. They just have one in the fusebox.
Yes the early cars had the "convenience" center. It has the key buzzer, choke heater relay, OBD1 connector, and a couple of other minor goodies in it.
Old May 17, 2023 | 05:43 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Is the "Convenance Center" fuse box supposed to pivot down, for access?
Old May 17, 2023 | 08:07 AM
Not that I'm aware of.
It's not "convenient" to the owner at all... I think that word only applied to the mfr. If memory serves, a few largely inaccessible screws hold it in; if you have the dash out and laying there, it's super easy, but with the whole car put together and you laying up under the dash, it's ANYTHING BUT "convenient".
Old May 22, 2025 | 06:51 PM
MarshallDang's Avatar
Hi, can anyone tell me where the fusible links for the headlights are? Thanks in advance.
Old May 23, 2025 | 07:42 AM
AFAIK there are none specifically for the headlights. They are fed off of one of the 2 main ones that each feed about half of the car's electrical system.
Asher36
Feb 24, 2013 04:13 PM
305blackbird
Jul 25, 2006 10:42 PM
ss7s
Jul 25, 2006 09:17 AM
84 Challenge
May 8, 2003 08:08 PM
