Name that wire game
Old May 29, 2023 | 07:46 AM
knightriderknut's Avatar
Car: 86 Trans Am
Name that wire game
Just going over the car to see what all minor things need to be repaired and of course the wiring under the dash has been "modified." Anyone want to play guess where this goes? The big random blue wire. Gonna trace it today but any guesses just for fun?
Old May 29, 2023 | 09:23 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Name that wire game
Does the blue wire terminate down by the gas pedal or dose it make a connection to another colored wire?
Old May 29, 2023 | 10:41 AM
Car: 86 Trans Am
Nope but i figured it out. gonna wait for a few more guesses lol
Old May 29, 2023 | 10:50 AM
Edwardgp's Avatar
Engine: 454-350
I believe it would be for radio or alarm system.
Old May 29, 2023 | 11:15 AM
Car: 86 Trans Am
Goes through the firewall. Power to the radiator fan.
Old May 29, 2023 | 11:34 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
No one can possibly tell you what that wire is for because it is not original to the car, not documented in any service manual, not even the right way to do things. Somebody just stuffed it in a fuse blade (probably randomly) and that's all we know.
My suggestion is eliminate it and pay attention to what might not be working and then fix that in a proper way. In the end, you're going to not need that wire because you're going to fix it right.
Old May 29, 2023 | 02:27 PM
The name of that wire is Hack Job. Mr Job, meet krk. Krk, meet Hack.
Find the other end. Repair whatever failed thing caused Stimpy to install Hack. Remove Hack.
Old May 30, 2023 | 12:25 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
There's a lot to unpack here.
Needless to say that these connectors need to be looked at.
I'm assuming an alarm module of some sort?
The orange wire is going from the fuse panel to the cooling fan or to the relay?
Should look at your fuses and what amp fuses need to used where.
Has the car been switched to carb, your injector fuses are missing, is that a 3 amp crank fuse?,
sszcam
May 8, 2010 09:31 AM
87camaro kid
May 29, 2009 02:33 PM
germ83
Jun 2, 2004 07:35 PM
Forza Juve
Car Audio
Feb 16, 2004 08:29 PM
