I have now power in my 1992 firebird
Old Jun 9, 2023 | 02:34 PM
Bearsav's Avatar
I have replaced the ignition switch, the alternator, and have a new battery, yet my car still does nothing there’s no lights, or sounds. I am lost and need help.
Old Jun 9, 2023 | 02:37 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: I have now power in my 1992 firebird
Start by checking the fusible links......
Old Jun 9, 2023 | 03:27 PM
^^^ This ^^^
Old Jun 9, 2023 | 04:47 PM
asilverblazer's Avatar
Check battery cables.
Quick check - bypass them with jumper cables.
Old Jun 10, 2023 | 08:19 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
...and all ground connections.
Old Jun 10, 2023 | 11:10 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Temporarily run a fused wire from battery positive to the batt terminal in fuse box.
that should backfeed some stuff to check and see if the fusible links are bad.
Old Jun 10, 2023 | 11:15 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
that should backfeed some stuff to chectoand see if the fusible links are bad.
fuse the test wire incase there’s a short
NKOSK92
Aug 8, 2021 01:21 PM
Rayella Parr
Apr 15, 2013 09:53 PM
clean86
May 15, 2009 05:30 PM
bsj
Aug 20, 2003 11:13 PM
