install new headlight help
Old Jun 26, 2023 | 09:22 AM
newguy93's Avatar
hello i just bought some new led headlight for my 1990 iroc … the problem is these new ones have 3 prong and the current ones are 2 prong … how do i convert them ? which harness do i get and do i need a relay? if you can post the link to the item i need here thank you in advance
Old Jun 26, 2023 | 09:44 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: install new headlight help
The low beams are 3 prong and the high beams are 2 prong. You probably got them switched up.
Old Jun 26, 2023 | 12:01 PM
newguy93's Avatar
your correct …. but all 4 that i bought have 3 prongs
Old Jun 26, 2023 | 12:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Which ones did you buy? Maybe they were miss packaged.
Old Jun 26, 2023 | 12:40 PM
newguy93's Avatar
https://www.ebay.com/itm/13456984484...mis&media=COPY
these are thes ones i bought
Old Jun 26, 2023 | 03:18 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It looks like one of the lights has two leads that split off before the 3 prong female connector. You should just be able to use those.
Old Jun 27, 2023 | 02:24 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Without seeing the instructions, I'd guess those two separate leads are for the DRL/Halo.
The two headlights you'll use for the main high beam/low beam might be plug-n-play, but the H4-style connectors on newer products like this tend to be wired differently than our older cars are wired. Are there are any markings or instructions that indicate which spade is for which function, high beam, low beam and ground?
You might need a short patch-style harness that allows you to re-pin the wires to match-up between the car's sockets and the headlight's plugs. Something like this found on Amazon, but there are a lot of other similar options available. They come in pairs, so if you need them, then you'll need two pair.
For the inner pair with only two wires each, high beam and ground, do the same thing. You'll be minus the low beam wire in each socket, and they should function as high beams only, like stock.
For full functionality of those two inner headlights, to give you four high beams and four low beams, then you'd probably have to tap the low beam wire and pin it into the empty third slot in each new socket. I don't know if that's the right or safest way to do it, but it would probably work. The four LED low beams combined probably draw less power than the two halogen low beams, so it's probably safe. But best to see how/if that works safely before you drive too far out into the middle of nowhere at night.
Old Jun 27, 2023 | 03:54 PM
vorteciroc's Avatar
Top Answer: 1
I wish people would stop using those JUNK Connectors/ Adapters...
And use the Delphi Connector with a Boot.
Bottom Right of Image below:
Right Side of Image again:
Bottom Center of Image:
Anyone can Contact me for these Parts.
Also, why do all of you guys want LEDs?
Honestly I don't think anything beats HIDs.
wife hates it
Sep 4, 2006 10:54 PM
CbrasTsteLkChk
Jun 2, 2005 09:28 AM
