86 camaro enable starter relay
Old Jul 16, 2023 | 02:31 PM
murphymckenna's Avatar
Car: 1986 Camaro Z28 Iroc-z
Hi guys just curious if my year camaro has a enable starter relay and where it is located I see it alot on 90 and above
Old Jul 16, 2023 | 02:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 camaro enable starter relay
No starter enable relay in 86 F body
Old Jul 16, 2023 | 02:36 PM
Ok thanks tuned performace, ok so my next question, which might be obvious, where do I start looking if I have a voltage drop, or short from the key to the starter ? I hooked up a starter switch and replaced the starter and all that runs fine, but the key won't hardly turn it over, and sometimes there is no reaction at all
Old Jul 16, 2023 | 02:48 PM
Engine: Lb9
Transmission: M20
It would be low voltage. You might start at neutral safety switch and check c100 condition.
Old Jul 16, 2023 | 02:49 PM
Engine: Lb9
Transmission: M20
Could even be adjusting the switch or bad ignition switch.
Old Jul 16, 2023 | 03:03 PM
Ok, awesome thanks man I appreciate it ill look through the other forums to get an idea what to do, but if and when I'm stumped I'll message back with questions
Old Jul 16, 2023 | 03:43 PM
Ok I have some questions about the neutral safety switch, how can you tell if it's bad ? Or is just an adjustment type deal maybe ?
mcbitchman
Sep 29, 2015 12:32 AM
Eli346
Nov 13, 2013 10:34 PM
Biggwinn
Apr 10, 2006 04:53 PM
linzbgoofy
Jan 15, 2003 08:52 PM
