Somebody HAS to know the fix for these windshiled wipers
Old Oct 25, 2023 | 12:12 AM
BlueBomber22's Avatar
So I am having the problem where my windshield wipers only move up and down two inches. I have tried multiple wiper motor units, replaced the wiper/turn signal switch, checked the wiper arm linkages, jostled the wires...literally nothing seems to solve this problem. What am I missing here?
I have a 1991 Firebird, the steering column is from a 4th gen(99?), turn signals work, wipers only start on "high" speed setting and even then only move 2 inches. All of the wires appear to be intact and connectors fully seated. Some PLEASE help me solve this issue. I feel like I've tried everything but nothing seems to work. Is aftermarket/offbrand wiper motor I can use? I searched the forums but any answers I found are vague and still don't help. Even youtube is leaving me high and dry here.
Man...anyway, please and thank you in advance guys.
Old Oct 25, 2023 | 05:12 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Somebody HAS to know the fix for these windshiled wipers
Originally Posted by BlueBomber22
.........I have a 1991 Firebird, the steering column is from a 4th gen(99?)......
If I had to guess, my guess would be that the 1999 switch won't work with the 1991 wiper motor. If you are actually using a 1991 switch in the 1999 column, then I have no idea other than checking all of the wiring, including the ground connection. In a normal, 100% factory stock wiper system, the problem you describe is usually found to be the circuit board in the wiper motor.....
Old Oct 25, 2023 | 09:48 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Well, first things first, what have you tried? Tested that the switch is good with a multimeter? Tested that the wiring is good with a multimeter. Probed the signals coming from the module? There's procedures in the service manual for going through and verifying that each part is working as expected.
Old Oct 26, 2023 | 01:37 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
if they are moving two inches and then back down, they're continually parking.
is the motor shaft making full revolutions?
mack1985transam
Jul 13, 2013 07:51 PM
phlipdawg
Apr 9, 2010 11:04 AM
Joe Lindsey
Aug 21, 2009 07:32 PM
Brothaman
Oct 25, 2007 10:21 PM
bluegoose
Mar 12, 2005 12:40 PM
