Driver side kick panel wires?
Old Oct 26, 2023 | 07:06 AM
JuanZ28's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.7 TPI
Need help identifying this wiring connecting into these relays. I have electrical problems.
Old Oct 26, 2023 | 02:04 PM
capted60's Avatar
Re: Driver side kick panel wires?
It's the door lock relay. Also the mounting screw must ground the case to the body or it will no function.
Old Oct 26, 2023 | 04:13 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Thank you.
Old Oct 26, 2023 | 04:15 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Old Oct 26, 2023 | 05:10 PM
OrangeBird's Avatar
Car: 1989 Firebird
Your video is indicative of a lost ground to your dashboard, the gauges that bounce in time with the turn signals are a classic symptom of a bad gauge panel ground.......
Old Oct 26, 2023 | 06:01 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Thank you Ive replace the turn signal switch, light switch and instrument cluster panel and still have that problem. Need to find a cut Ground wire?
Old Oct 26, 2023 | 06:41 PM
OrangeBird's Avatar
Car: 1989 Firebird
Yes, one of the wires that brings the ground to your gauges has lost it's connection. Since you've replaced the instrument cluster and the problem persists that's very strong evidence for the lost ground being in either the dashboard connector (not likely, but it does happen) or the wiring. I'd be looking really close at all of the black wires in and around the dash area for any that have been cut, sometimes when people put aftermarket radios in all kinds of wiring bukkake takes place, so anywhere where the wiring has been disturbed would be a great place to begin the search for the missing ground....
Old Oct 26, 2023 | 08:15 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Will do this weekend and will update. Thanks
george88gta
Jan 18, 2023 02:54 PM
Formula1791
Aug 13, 2022 10:38 AM
battmann
Jun 13, 2021 06:09 PM
amoede
Exterior Parts for Sale
May 3, 2015 10:43 AM
