Dakota SGI-100BT question
Old Feb 29, 2024 | 01:12 AM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Back again with my speedometer! However this time i have just decided to go the easy route and pickup a SGI-100BT, i have a few questions for anyone who has installed one of these on a 1991 factory tpi vehicle. First question is could someone possibly post a picture of their SGI setup without a buffer box? And last question regards wiring, i know which wires i need to run into the SGI however do i cut them before they meet the ecm or is there another way i should be doing this?
Old Mar 1, 2024 | 11:15 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Dakota SGI-100BT question
Are you using the ecm as a buffer or for tcc lockup ?
Old Mar 1, 2024 | 11:21 AM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/elec...sgi-100bt.html
if bypassing the ecm buffer c207 brown wire at ecm pin b11 is output to speedometer.
Old Mar 1, 2024 | 11:40 AM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Hey man thanks for the reply! My car was actually a TPI from factory so it has the buffer built into its ecm so it doesnt have one of those yellow buffer boxes and with all the hacked up wires i plan on just bypassing it as a whole, looking over the wiring diagram (ill attach below) if im correct wouldnt i just cut the yellow and purple vss signal wires at the ecm along with the grey wire that runs to the gauge itself from the c207 connector and connect them into the Dakota Digital box? Just wanna do this the cleanest way and not destroy and more of the wiring harness than the previous owner did. Below is the wiring diagram i am referencing thanks again for the help!
Old Mar 1, 2024 | 11:48 AM
Engine: Lb9
Transmission: M20
Correct the ip wire could be grey or brown. You can power the sgi from c207 the ecms a6 pink/blk wire.
Old Mar 1, 2024 | 12:10 PM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Perfect thank you very much! Was actually wondering which power wire i could tap i to but you beat me to it! would one of the empty fuse slots marked BAT also work as a power source if i chose not to splice into the pink/black?
Old Mar 1, 2024 | 12:38 PM
Engine: Lb9
Transmission: M20
You would have to test the fuse box for a hot key on and run accessory power.
Old Mar 1, 2024 | 01:12 PM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Your the best man! Thank you for all the help, ill update with pictures in the near future once i get everything wired up and working just incase anyone else ever wonders exactly what needs to be cut and where.
Old Mar 2, 2024 | 05:09 PM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Hey man i actually somehow managed to come up with another question do you happen to know where the vss sensor wires enter the car at? Ive been looking on the diagrams and i cant seem to find anywhere where it mentions where they come in through. First idea was maybe around where the shifter is? Figured id ask before i go digging haha sgi come in tomorrow!
Old Mar 2, 2024 | 07:11 PM
Engine: Lb9
Transmission: M20
Should be in the pass through connector under passenger side kick panel.
Old Mar 2, 2024 | 08:50 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Not sure of what you're saying here, buy I hope you're not intending to completely bypass the ECM from the VSS. ECM needs a speed input to control other things besides speedometer. If not then disregard.
Old Mar 2, 2024 | 09:12 PM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Im first gonna try placing it after the ecm so i dont need to cut the purple and yellow vss wires from it however i have a carbureted engine in it now so if that also does not work then i will cut it from the ecm as none of my gauges are wired into the ecm besides the speedometer.
Old Mar 2, 2024 | 09:15 PM
Engine: Lb9
Transmission: M20
what ? Your going to hook on the buffered signal ?
Old Mar 3, 2024 | 01:26 AM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Before i cut the two vss wires that go straight into the ecm by the passenger side kick panel yes, im gonna just try to recalibrate the signal right at the c207 as ive stated in previous past im not the builder of the car however i do own it now and i can tell that it absolutely has a different rear end
ratio so im going to attempt that first if that doesnt work im gonna assume there is some fault in the ecm somewhere as i believe the gauge cluster istself is good every other gauge works besides the speedometer and odometer. the speedometer does move a tiny bit once the car is started it just freezes in place afterwards, the car also drives and shifts just fine so i dont think it could possibly be the speed sensor as id believe id have a check engine light or code for it. Ive had this problem for over a year now and im either gonna fix it by recalibrating the signal at the grey wire at the c207 or i cut the purple yellow and grey vss wires at the ecm and sending them straight through the dakota sgi-100bt and to the gauge
Old Mar 3, 2024 | 09:06 AM
Engine: Lb9
Transmission: M20
The sgi can take an optical signal and give out an optical?
Old Mar 3, 2024 | 09:12 AM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
From what i was told yes, i contacted their tech support and i was told to cut the purple and yellow wires before the ecm connector and connect them into the sgi and then also connect the grey wire from the c207. Thats basically why i came here i wanted to make sure that was correct before i cut i to anything
Old Mar 3, 2024 | 09:18 AM
Engine: Lb9
Transmission: M20
I’d just hook it up magnetic pulse input optical output.
Old Mar 3, 2024 | 12:11 PM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Which way would that be? Place the box after the ecm at the grey output wire and attemp to recalibrate the signal right there or should i do as the dakota digital tech said and and connect the yellow and purple wires into the sgi along with the grey wire that goes to the instrument panel?
Old Mar 3, 2024 | 12:19 PM
Engine: Lb9
Transmission: M20
As tech support describes. But I’d be concerned about tcc lockup with a carb. Tci makes a kit then ecm could be fully bypassed.
Old Mar 3, 2024 | 01:00 PM
ill's Avatar
ill
Car: 1991 Z28
Engine: 383
Taking that into note i probably will try and just use the sgi to recalibrate the signal wire (grey wire) thats going to the instrument cluster as i actually got two responses from two different techs over at Dakota Digital one saying he always puts the sgi after the ecm and then one telling me to put it before the ecm at purple and yellow vss wires+the grey instrument panel wire. As im going to need to disconnect the grey wire from the c207 either way i do it im gonna attempt the way that doesnt involve cutting the purple and yellow wires first.
devilfish
May 5, 2008 10:25 AM
biff76111
Dec 3, 2005 12:59 AM
precision351
Mar 18, 2003 09:04 PM
