FUEL PUMP FUSE
Car: 2020 chevy camaro ss and a 86 z28
Engine: 5.0 305
Transmission: 5 speed
Axle/Gears: Stock
FUEL PUMP FUSE
Hi I have a 1986 z28 305 4 barrel carb 5 speed car. I can not find the fuel pump fuse I looked by the front passenger side inner fender by the battery and its not there. Problem with the car is I have no fuel going to the carb. I cant hear the fuel pump buzz with key on. I changed the relay and still nothing. I am trying to check all electrical before I drop the tank.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: FUEL PUMP FUSE
On my 86 TA the fuel pump fuse is a 10 amp (red) and its located on the second from the left at the top of the fuse box,
there will be red,red violet and yellow in that order. Hopefully their the same.
PS that fuse is also for the oil pressure switch
