Ground wires on back of head
Old Mar 26, 2024 | 02:48 PM
Nutro's Avatar
I got a used 91-92 Z28 harness and I am going through and inspecting every wire and will be fixing any issues and Tessa taping and split looming it. I found a wiring diagram and I think these 3 black/white tracer wires are grounds to the back of the head. I believe the tan wire is too. The diagram I found shows this should be on passenger side but these are definitely drivers side.
Also, that little orange wire, does anyone know what was supposed to be on that cut end?
Old Mar 27, 2024 | 07:25 PM
Nutro's Avatar
Re: Ground wires on back of head
Bump? Anyone out there
Old Mar 27, 2024 | 10:21 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Trace them (check continuity) to the pinout on the other end and look that location up in the diagram.
Old Mar 28, 2024 | 07:38 PM
Nutro's Avatar
The diagram I was looking at doesn't even seem to jive with these wires. Does the C100 etc show ground locations
Old Mar 28, 2024 | 08:03 PM
Pretty sure the tan wire isn't a ground.
Oil pressure sending unit maybe?
Old Mar 28, 2024 | 08:15 PM
Nutro's Avatar
I thought that as well but this harness has the 3 wire Oil pressure sender. I need to find the diagram again but It showed 3 black/white wires as grounds and I think it showed a tan as "Ground reference" but I've been super sick and on meds so maybe I dreamed it haha
Old Mar 29, 2024 | 08:12 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Have you reviewed the wire diagrams available on https://austinthirdgen.org/.
Old Mar 29, 2024 | 08:31 AM
Nutro's Avatar
Yep, thats where I found them before, going to re-check now
Old Mar 29, 2024 | 09:16 AM
Nutro's Avatar
Ok so 112 is the driver side head ground and 118 is passenger side head. This is where I am confused. In that diagram, it shows 112 as having 2 BLK/WHT and the TAN but I have an extra BLK/WHT making 3 total plus the TAN.
Old Mar 29, 2024 | 09:35 AM
Nutro's Avatar
Ok! I OHM'd it and found it in the 32 pin green ECM connector. My mystery TAN wire is the O2 sensor ground. Now, does it ground at the head with the BLK/WHT wires or somewhere else?
Old Mar 29, 2024 | 10:24 AM
Nutro's Avatar
Ok so my BLK/WHT wires are apparently ECM ground, Injector grounds. The last one to figure out is this orange wire and it goes to a clear connector and is in position "M" but I cannot figure out what connector this is.
Old Mar 29, 2024 | 06:32 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I think that is the connector that interfaces with the body. Some of the wires go to the ALDL. Another wire goes to the check engine light. The stock fuel pump 12+ goes through that connector. Not sure about the "M" wire. I will have to check my 92 F-body shop manual.
Update: I checked my 92 Camaro shop manual. I think that is connector C207. Pin "M" is stated to be orange and it is listed as "Interior Lights, Underhood Light."
Fred
Old Mar 29, 2024 | 08:28 PM
Nutro's Avatar
Yep I found out its the underhood light and the red plug next to it is the fuel pump prime? I think I have most of the cut/damaged wires figure out now. Hopefully anyway
Old Mar 30, 2024 | 04:08 PM
Fred SS's Avatar
Transmission: 2004r
If you have any other issues, post it up and hopefully we can help.
Fred
Johny2234
Jun 20, 2021 02:02 PM
SweetRed87
Sep 29, 2016 03:12 PM
f_body_4_life
Jan 26, 2009 04:00 AM
drb930
Nov 19, 2007 09:15 PM
