Oil/Temp gauge hookup
Old Apr 9, 2024 | 06:29 AM
350orbust's Avatar
Car: 84 Z28
Engine: 350c
I have an 84' Z28 carbureted 350 swap. I didn't do the swap, but I'm guessing my oil pressure and water temp gauges never got hooked up when the swap was done (needle is always in the red, and doesn't move). Any clues on how to fix or even where the sensors are located? Video guides are always appreciated, as I don't have a lot of experience with engines.
Old Apr 9, 2024 | 08:46 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Oil/Temp gauge hookup
For temperature, look for a sensor that is screwed into the intake, probably near the front of the engine.
For oil pressure the sending unit should be near the back of the engine and will either have two or three prongs on it depending on which kind was put in.
If both of those appear to exist, and be plugged in correctly, then i would pull the gauge cluster and check the gauges. You can find youtube videos, etc. on how to do that with a multimeter.
FireDemonSiC
Aug 15, 2009 11:08 AM
stroke6463
Aug 28, 2007 12:22 PM
chevyrumble83
Apr 5, 2004 05:24 PM
MartinC
Jan 7, 2002 01:53 PM
