Fuel Pump Relay
Old Jul 14, 2024 | 12:59 AM
jacksonsm1921's Avatar
Fuel Pump Relay
Hi everyone, I have an 82' Trans Am with the 4BBL carb and cannot locate the fuel pump relay for the life of me. I have checked near the battery, and on the firewall in the engine bay on the driver's side where it is supposed to be. It does appear that there are two separate connectors on the driver's side firewall plugged into one module, but that's it. Any help is appreciated thanks!
Old Jul 14, 2024 | 01:36 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Fuel Pump Relay
There isn't one. A factory carbureted '82 Trans Am has a mechanical fuel pump on the engine block.
Old Jul 14, 2024 | 08:05 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Fuel Pump Relay
I have a 1984 (export car to Canada) with a QJ & mechanical fuel pump
Old Jul 14, 2024 | 07:16 PM
Re: Fuel Pump Relay
Thank you so much. With that being said, is there a way to “cut power” to the mechanical one? I am trying to perform a compression test but have already removed intake manifold and carb. So when I go to crank the car to check for compression, fuel is just going to spray everywhere. Thanks!
Old Jul 14, 2024 | 08:29 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Fuel Pump Relay
Unbolt it from the block or unhook the fuel line from fuel tank and plug it so tank doesn't empty on your floor.
Old Jul 15, 2024 | 12:36 AM
Re: Fuel Pump Relay
Perfect! Thank you so much!
Chevy86 IROC-Z
Dec 12, 2017 03:58 PM
spkx714
Sep 1, 2010 08:16 AM
MannMadeCustoms
Dec 12, 2009 08:13 PM
WaaX
Oct 30, 2005 05:06 PM
