Trunk release switch
Old Sep 6, 2024 | 04:22 PM
19eighty4_z28's Avatar
Car: One Chevy built in the 80s
Engine: 5.7 crate
Axle/Gears: Quick performance 9” 3.70
Odd problem but my 84 will only pop the trunk with the ignition in the on position. Never had this problem before…any hints on what/where to look? Switch worked fine before. New switch installed and problem followed
Old Sep 7, 2024 | 10:16 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Trunk release switch
With an Automatic the hatch should not be able to open unless the car is in PARK or NEUTRAL; with a Manual it should only open if the E-Brake is pulled up/active. With Auto and PARK; the button should work fine and the hatch should POP regardless of key position, with Auto and NEUTRAL the Key would have to be turned to BULB TEST. These are the only times the hatch Solenoid should function.
Maybe there is a problem with the NSS,...... or Maybe you've got the wires hooked up wrong on the new button ??
Old Sep 7, 2024 | 01:21 PM
Engine: 5.7 crate
Thanks for the info. I did have the trans replaced a few months back while it was in the shop. It has a B@M shifter in it which needed some switches replaced as well. I’m guessing somewhere in there lies the problem.
podiatra
Jul 26, 2015 08:16 AM
jcard45
Jun 17, 2011 07:59 PM
Kraigs 91 Z
Interior Parts Wanted
Oct 16, 2006 06:10 AM
Randy92Z
Convertibles
May 14, 2004 10:09 AM
