Starting problem
Car: 91 Camaro
Engine: 5.7 TPI
Starting problem
Hi!
so I am having starting issues. When I turn the key, 27.2% of the time it will start; the other times, I get a single click...sometimes if I leave the key turned for an extra second it’s starts. Battery is full, I can jump the purple wire and start the car 100% of the time. Anybody dealt with this before? Where do I need to start the troubleshooting process? Car is a 91 5.7 TPI
Re: Starting problem
Hi!
The test light, when properly applied, will show you exactly where the fault lies..........
Car: 1984 Trans AM
Transmission: 700-4r
There is also one other possibility from past experience.if there is a dead spot on the armature that would present like your problem. Had that happen & eventually got a different starter.
Given that he said it starts only sometimes with the key, but starts every time he jumps power to the purple (solenoid) wire, a "dead spot" in the armature doesn't fit into the description of the encountered symptom
" I can jump the purple wire and start the car 100% of the time."
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Ignition switch is probs on the way out
WhiskeyChick
May 16, 2014 10:25 PM
CamaroRS1989
May 4, 2009 07:29 AM
