Car Wont Stay On
Old Jan 23, 2025 | 11:08 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Car Wont Stay On
This past weekend, I decided to start my car. The battery was dead so I used my jump pack and the car roared to life for about 10 seconds and then totally died. And when I say died, everything went dead like someone pulled the plug on it. This happened each of the three times I attempted to start it up. The Powermaster 140amp alternator is not even two years old and I am running 2 gauge battery and alternator wiring. The fuses are fine as well as the grounds. This is the first time it ever happened to my car. Any ideas?
Old Jan 24, 2025 | 12:31 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Car Wont Stay On
Gotta' start somewhere,.... Fusible links @ the starter on the "power" side,...... and check Negative Battery cable ground @ the block & the body. I wouldn't just tug & look,.... I'd loosen all the hardware and re-torque.
Fusible links often fail in an "intermittent" way,.... They might check-out OK when probing and the key is OFF,..... but test results will change when there is a 'load' on the circuit.
Not a bad idea to load-test the battery too; just so that you can remove it from the list of suspect parts.
Like I said - Gotta' start somewhere !
Old Jan 25, 2025 | 06:35 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I just got my order of new fusible links in 8 AWG size since I'm running 2 gauge positive and negative alternator and battery cables. A bit overkill and since I'm down by the starter, going to heat wrap the wiring there. Grounds are ok btw. As for the battery, I'm just going to ditch the Costco one in there now and get an O'Reily's one even though I'm fairly certain they're both made by the same manufacturer.
Old Jan 25, 2025 | 08:10 PM
NoEmissions84TA's Avatar
You jump a WEAK battery - this is what can happen when you jump a DEAD battery.
Old Jan 26, 2025 | 07:56 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Probably a loose battery terminal or bad ground. As previously said, pull on the cables and ensure everything is connected properly; could be a fuseable link but I would put more stock into a loose connection. Easy to test with a multimeter- after the car has died test voltage at the battery and then voltage at the alternator output and starter positive to see if you are getting solid battery voltage to the engine. Also charge the battery until you have at least 12.6 volts, if you are using a smart jumper that cuts off when it sees alternator output and the battery is dead, the car will die.
Old Feb 24, 2025 | 10:24 AM
MY87LT's Avatar
Car: 1987 Camaro LT
This weekend I directly hooked up my jump pack to the battery cables without the battery and the car started up fine and stayed on no problem once I disconnected the jump pack. But, later in the day, I tried to to the same thing with the same, and recharged jump pack and the car died after 10 seconds. Got a new battery yesterday and will try again this weekend. I popped it in the car, just didn't connect the cables yet as not to potentially drain it. The grounds and ground straps are fine. Fusible links seem ok. Haven't been able to get under the car, just from what I can see to the starter through the headers.
crackerjackz
Jul 21, 2010 09:29 PM
mizzmaro 89
Jun 28, 2008 03:31 AM
PAformula
Oct 4, 2005 09:54 PM
nikh23
Apr 21, 2002 03:16 PM
KCobain147
Dec 26, 2001 10:41 PM
