1992 Camaro RS 5.0 Won't start or crank after just driving
Im currently having issues where my starter is not engaging. The problem first started after going on a 30 minute drive with Zero issues until I put the car in park and turned it off. Now the car won't start, the only thing that happens when I turn the key is the fuel pump priming and gauge cluster lighting up. Whenever I insert the key and turn it the fuel pump primes and when I fully turn the key everything is quiet, there's no tick, hum, or any noise I can hear.
LIST OF THINGS I'VE TRIED
*Replacing the starter with a brand new one, tested the new starter before installing it and made sure all the wiring was hooked up correctly.
*I tried using my second key
*I tried to bypass the VATS (Vehicle anti theft system) by cutting the wires going from my ignition and replacing it with a resistor the same resistance as my key which didn't work
* I also tried replacing my starter relay which didn't work
And I tried to bypass the starter relay and got nothing
*And I've checked all the fuses and connections that I could easily get to for any damage and still haven't found anything
if anyone has any idea what the problem could be I'd be extremely grateful.
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: 1992 Camaro RS 5.0 Won't start or crank after just driving
