Starter help (im slow)
Old May 22, 2025 | 03:44 PM
slowest305T5's Avatar
I am putting in a new starter for my 84 305 firebird, I have three wires, the ignition wire, and what seems to be a power and a ground wire. I can’t imagine the starter needs three wires but i remember taking three off. I just need help
Old May 22, 2025 | 04:42 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Starter help (im slow)
The starter is grounded by its mounting to the block. Most likely what you have is the battery positive and fusible links, both got to the large stud on the solenoid
Old May 22, 2025 | 05:15 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Yep, there's no ground wire. There's a purple wire that connects to the "S" terminal, and the positive battery cable plus two wires with fusible links that connect to the main power stud...
Austin Erwin
Feb 8, 2017 09:48 PM
billybob6110
Dec 29, 2009 12:52 AM
jocww
Jan 22, 2005 10:20 PM
1987IROC
Jul 21, 2002 04:47 PM
