Alternator/Battery volts
Car: '89 Firebird
Engine: 7.0L
Re: Alternator/Battery volts
Same engine speed, same electrical load.
You can do it when things are fine, you can do it when things are misbehaving. And then compare results.
Let's get wild and crazy and make up a 10ga piece of wire and connect it from the battery to the alternator and go for a spin and see what happens. Of course I'm assuming that each and every other connection of both ends of the battery cables is bright and tight. Also assuming that the grounds are all good, electricity has to go home.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
