Stop lights and 3rd brake light don't work
Old Oct 10, 2025 | 10:43 AM
Adam1989's Avatar
I have no brake lights when I depress the pedal but have power going to the switch with the key on. Turn the key off an no power. Shouldn't I have power all the time at the switch. Or the power only comes on only when the switch is activated? Did I answer my own question?I have power on both brake switch terminals, pink and purple with the key is on. Is the brake light switch bad?
I think I'm looking at the wrong switch. Is it the switch with two pigtails.
Old Oct 10, 2025 | 11:16 AM
Re: Stop lights and 3rd brake light don't work
Doesn't sound right.
Pretty sure the BL sw will have an orange and a lt blue wire. Orange is hot at all times.
Check the Stop/Haz fuse first.
Old Oct 10, 2025 | 12:22 PM
Adam1989's Avatar
Your right. I had the wrong switch. I jiggled the wires to see if the 3 light would come on. It did a couple of days ago but don't any more. I need to find out which two wires are used for the 3rd light so that I can check them. I got brake lights, 4 way flashers. It looks like a very difficult job removing the switch. I saw one youtube video showing that the brake assembly needs completely removed.
Old Oct 10, 2025 | 09:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The switch just pulls off, ratchet style.
Old Oct 10, 2025 | 09:38 PM
Adam1989's Avatar
Thanks. Appreciate it. Now I see the two wires I need to check. Yellow and looks like blue.
Old Oct 10, 2025 | 09:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Blue is the tail/brk lights, yllw is the TBL.
Old Oct 11, 2025 | 01:31 AM
Adam1989's Avatar
Thanks for that information. Seems like everytime I fix one problem, another pops up.
Old Oct 11, 2025 | 10:24 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yep, the more you look. The more you find.
Old Oct 11, 2025 | 10:43 AM
The regular brake lights go through the hazard flasher switch in cars that use the same bulbs for hazards and brake lights. The 3rd light needs to come on whether the hazards are on or not. Not sure why they used a 2-pole switch; seems as though the CHMSL could have been fed off of the blue wire right at the switch, butt what do I know about complicated electrical things like ... lights ... anyway.
Old Oct 11, 2025 | 12:17 PM
Adam1989's Avatar
Just today, I eliminated the brake light switch as defective. Got frustrated and put the car in storage. It gave me problems even putting it in storage. After 3 IAC's and doing different procedures to get it in sync with the ECM it stalled just as I was entering the storage unit. Started it again and disconnected the negative post locked the unit and left. Next year it's going to a shop to get everything fixed. After that, putting it out there for sale. I've had it with the Trans Am GTA. Hardly used it. 36 year old car with 24,000 accurate miles. Here's a laugh, 666 miles per year. It's red so it must be Christine's long loss relative.
a1990camaro
Aug 31, 2021 09:57 PM
johntaylorny
Dec 16, 2016 09:24 AM
Badrs2810
May 28, 2012 07:50 AM
GM Man
Mar 18, 2009 09:04 PM
Need4Speed1387
Oct 14, 2003 09:03 PM
