Anybody know what alternator this is?
Old Oct 19, 2025 | 07:46 PM
cotto1122's Avatar
Trying to determine what alternator this is. Believe it’s going bad as brand new battery is drained, and after jump start and running for a bit battery volts are reading even lower.
The cars an 87’ but I know the previous owner switched it over to a Serp Belt system as I needed a 88’ water pump when I replaced that.
Old Oct 19, 2025 | 10:24 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Anybody know what alternator this is?
That's an 88-92 style CS alternator. You should be able to buy a replacement for a V8 in that year range and have it bolt in.
Old Oct 20, 2025 | 08:40 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Have it rebuilt..
Old Oct 20, 2025 | 08:44 AM
cotto1122's Avatar
What’s your reason for rebuilding as opposed to to just buying a new one? Just curious, I’m sure it’s not that cost effective, unless you DIY and that would be a first for me.
Old Oct 20, 2025 | 03:26 PM
72buickgs's Avatar
Car: 1984 Trans AM
It is less expensive to have a an original alternator or even an orig carb rebuilt.
I have had the orig QJ & alternator on my '84 Trans AM rebuilt.
Have the chance to NOT rebuild using Chinese parts.
Who knows were the new alternator is built? China, Asia
Old Oct 20, 2025 | 04:31 PM
BURD's Avatar
Last time I took an alt in, it was 20$
Last starter was free. I gave the guy 20 for lunch. Just a ground
Old Oct 21, 2025 | 01:07 PM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
Looks like a 105 Amp CS130 made by ACDelco
$133.17 at Rock Auto.
You can buy a rebuild kit from Tuff Stuff for about $55 if you are good with your hands.
The new battery draining might be a bad alternator but it could also be a light left on or a bad courtesy light switch somewhere.
Try this
Charge the new battery.
Test the voltage. If you have a volt meter in the car with the key on but no engine running, note the voltage. It should be about 12.6 to 12.8 volts.
Start the car.
Check the voltage again. If the alternator is charging the voltage with the engine running should be about 13.6 to 14.7 Volts.
If the voltage stayed in the 12.6 range you have a bad alternator, if the voltage goes up over 13.6 volts you have some other electrical issue.
Old Oct 21, 2025 | 02:47 PM
cotto1122's Avatar
I’m gonna have it rebuilt found a local guy that gave me a half decent price rather than trying to tackle it myself. The battery is showing 12.5 when off, but I had it running after a jump start and it when down into the 8-9 range.
1986 stinker
May 1, 2024 10:56 AM
blueta89
Dec 21, 2004 10:00 AM
redberlinetta86
May 14, 2003 07:09 AM
Dingley
Jan 26, 2003 10:48 AM
JETHROIROC
Feb 22, 2001 09:23 AM
