Help to ID a mysterious connector in the center console
Old Dec 18, 2025 | 03:28 PM
max_est's Avatar
Car: '89 RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.42, 10-bolt
1989 Camaro, originally V6 T5. I'm trying to undo the hatch pulldown delete done by previous owner(s) and I'm struggling to find a connector for hatch release switch. The only connector I have in the center console is this and it doesn't seem it’s for hatch release and I have no clue what it's for. Search didn’t give any clues. Any ideas are appreciated!
Old Dec 18, 2025 | 06:13 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Help to ID a mysterious connector in the center console
Off hand I do not recall what that connector may have been used for, but those wire colors are for a dome/courtesy light circuit.
The remote hatch release was optional and not part of the standard power pull-down latch.
Old Dec 19, 2025 | 06:56 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
Thank you! Didn't know that. I was confused because I have all the wiring in the back, incl. connector for the release solenoid. It seems that some new wiring needs to be fabricated...
Old Dec 23, 2025 | 08:11 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The analog clock that mounted on the console in early camaros used that connector. It may just be a leftover since that option was nul by the time your car was built.
Old Dec 23, 2025 | 08:43 PM
Engine: that I like
Oh yeah, that's right. Out of curiosity's sake, I'm gonna have to look at a diagram. Black is obviously ground. Orange is constant 12v. But white is typically door jamb switch. Or is it a gray wire in the picture?
Old Dec 23, 2025 | 10:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
White IIRC, its for the two lights in the clock. Works off the gauge lighting
Old Jan 10, 2026 | 03:41 PM
max_est's Avatar
Car: '89 RS
Engine: LS3
Solved the "mystery". Traced the wires and:
1. Black goes to hatch release solenoid connector.
2. Orange is 12V from ACC fuse.
3. The middle one with the stripe is connected to the handbrake switch.
To me it seems that my base model received partial wiring and some wiring (from this connector to the hatch release relay and release switch) is missing. As 86blackiroc pointed out, probably my car came without remote release because hatch release assembly (or what is left of it) doesn't have release solenoid, only manual release. I cannot confirm because the central console is replaced by previous owner(s) and thus RPO codes are gone.
From service manual, it seems that this connector is coded C241: it has black, orange and tan/wht wires. I'll try to find the type of this connector to buy male connector for this plug.
Thank you for your help and time!
Old Jan 10, 2026 | 06:03 PM
Engine: that I like
You just jostled my memory. Is your car a manual trans? Nearly 20 years ago, I manual swapped one of my 86's. I remember having to do some rewiring on the hatch release switch so that the brake lever had to be pulled for the hatch release to operate. That's all I remember though, lol.
Old Jan 11, 2026 | 04:12 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
You are correct, it's a manual.
In case someone will be in the same situation, here are the links to the connectors:
* 12020398 - Delphi Metri-Pack 280 Unsealed 3 Way Male Connector: https://www.customconnectorkits.com/...KaKHQEWJassDHY
* 12020397 - Delphi Metri-Pack 280 3 Way Black Unsealed Female Connector: https://www.customconnectorkits.com/...cowNFmPiI2A66y
NJ2FLIROC
Oct 31, 2022 09:32 PM
Mad Max
Jun 12, 2012 12:47 AM
motoman9790
Mar 23, 2010 12:10 PM
BackInBlackGP
May 19, 2004 05:10 PM
