Need help identifying sensor
Old May 7, 2026 | 10:22 PM
DigitalDan3's Avatar
Car: 1988 Firebird Formula
I’m working on a 1988 formula 5.0 mpi auto. I was doing a spark plug change, car sat for 18 years, I noticed a wire hanging down that hat a pin on the end and part of a ribbed water tight boot. Between plug 4 and 6 there was also a sensor type device screwed into the block that looke to be where this plugged in. When I touched the plastic end of the sensor it disintegrated. I need help identifying it so I can replace the electrical connect and the sensor itself.
Old May 7, 2026 | 10:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need help identifying sensor
Knock sensor or cylinder head temp sw
Old May 7, 2026 | 10:27 PM
Engine: Lb9
Transmission: M20
https://ebay.us/m/nkb9h0
Old May 7, 2026 | 10:36 PM
Plugs 4 & 6 are screwed into the head. The block is ... the block. Which is not the head.
Which is it?
If it is what it sounds like, which is, it has NOTHING WHATSOEVER to do with the head (spark plugs), butt rather is right exactly dead center front-to-rear of the BLOCK about an inch or so above the oil pan, it's the knock sensor, otherwise cleverly disguised as the pass side coolant drain plug. See, those [forrest_gump] smarrrrrrttt [/forrest_gump] engineers at GM, knew back in the early 50s, that electronically controlled fuel injection was a-comminn, and they made a provision for it, in "stealth mode" so that their competitors (the d00dz that placed lower in their graduating engineering classes) at Frod and Xler, wouldn't get a glimpse of what they were up to. So, they disguised the future knock sensor port, as a coolant drain. Clever. Genieass. Not sure I measure up.
So as said, what it sounds like you're working on, is the knock sensor. Be aware that it's also the pass side block coolant drain; therefore when you pop it out, there's a finite and VERY non-zero chance that EVERY BIT of the coolant in the engine except for about a gallon in the driver's side of the block, will come pouring out. Should be maybe 3 gallons or so, maybe a bit more. So be prepared accordingly. Great opportunity to do a COMPLETE coolant drain flush & renewal if you also take out the driver's side plug, all of which I highly recommend.
Old May 7, 2026 | 10:43 PM
Thanks all. It looks like the knock sensor, the mushroom shaped plastic end disintegrated when I touched it. The wire hanging down still had a pin on the end but the outer plastic connector must have disintegrated too. Thanks for the heads up that the coolant will drain from them.
Dan
Old May 8, 2026 | 11:22 PM
vorteciroc's Avatar
Top Answer: 1
Which is it?
Hey Now!!!
Don't be tellin' all dems apeople all OUR aspecial seacrits now!
Just kidding!
rfcomp
Oct 11, 2011 07:35 PM
mechanic1992
Feb 22, 2010 09:35 PM
fychelio
Jan 24, 2009 05:31 PM
ROCHEAD
Sep 15, 2002 02:33 PM
Don_89Iroc
May 15, 2002 04:22 PM
