Wiper pulse board
Old May 8, 2026 | 11:56 PM
Koyna's Avatar
Engine: 400SBC
Wiper pulse board
So I’ve been searching forever to try to find a new pulse board. Mine is damaged and no longer works. I have not had any luck trying to find a replacement and it appears that they are no longer being made or there aren’t any replicas.
So does anybody have any experience on a different motor and pulse board that can work?
I figure somebody has to have some experience with something aftermarket or from a different vehicle that can get put in and work
Any help would be greatly appreciated!
Old May 11, 2026 | 11:50 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wiper pulse board
What year is the Wiper Assembly ??
IIRC the later style ( 88-92) Thirdgen Wiper Assembly was also used in some other GM cars. If you don't want to go with used parts, you can still find NOS sometimes:
https://www.ebay.com/sch/i.html?_nkw...490.m570.l1313
Here is a older thread with all the wiper info that might possibly help you find what you need !
https://www.thirdgen.org/forums/hist...ml#post4472150
Old May 11, 2026 | 04:35 PM
Koyna's Avatar
Engine: 400SBC
Mine is 1985. I saw they changed in 88 looks like the same bolt pattern though
Old May 12, 2026 | 12:10 PM
John in RI's Avatar
Ya',.. the 88-92 will bolt-up, but it's a different Assembly and the cover IS different; What you need will be from an 84-87.
The older they get, the harder they are to find ! The problem I always had with the Wiper Assemblies is that I couldn't tell if it was a High/Low or a "pulse" unit just by looking at it. I'm sure you can tell once the cover gets removed - but not when just looking at the thing ! I know that the 84-87 Wiper Assemblies are getting harder to come by, but with some persistence you'll be able to find sumthin'. I do have a couple of these on my own garage shelf right now - but I don't have a away to ID and am not interested in climbing up to that shelf to take them apart to figure out exactly what they are when I can't even test them.
I searched quick and found this,...... Item # 236692361214 . If you send the auctioneer a question asking to see pics of the Wiper Motor itself AND the turn signal stalk on the column, then you might get lucky and have found a cheap 'pulse' Wiper Assembly. If not him - then post a "wanted" add in the TGO classified section and eventually another member here will hook you up.
In the meantime; If I get access to an 84-87 Thirdgen any time soon - I'll test what I've got here and will update this thread if anything works.
Old May 12, 2026 | 12:50 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
While we're on the subject; is there an after-market wiper delay available for converting to intermittent wipers on a thirdgen?...
Old May 12, 2026 | 03:32 PM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
Is this what you are looking for?
WIPER MOTOR CIRCUIT BOARD ,W/PULSE USED 84-88 F-G BODY – Chicago Muscle Car Parts , Inc.
If nothing else there is a cross reference to other car models that this board fits to do further searches.
Old May 12, 2026 | 06:32 PM
Koyna's Avatar
Engine: 400SBC
yeah but you can’t checkout on that site. I’ve tried there.
Old May 12, 2026 | 06:33 PM
Koyna's Avatar
Engine: 400SBC
so I found one early years then two from 88-92 at the junk yard yesterday.
mcbitchman
May 6, 2022 03:27 PM
rusty vango
Nov 25, 2019 02:27 PM
mack1985transam
Nov 12, 2012 09:34 AM
