Help!! Head light Problem..
Old Feb 5, 2002 | 06:38 PM
vinay's Avatar
Hi My car {92 305tbi} has a problem with its Headlights, I just noticed that my driverside head light isnt working and so I just tried the Hig Beam and when the high beam is on all the four headlights are on but when I switch it back to low beam only passenger side headlight is functioning!! Please help!! what do I need to do about this as I have no clue about electrical things!!Help appreciated..
Old Feb 5, 2002 | 06:57 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Try replacing the dual filament hi/low beam (outer) bulb on the driver's side (if you have a Camaro). If you have a Firebird, or T/A I believe that there's only one head light per side - replace it.
Old Feb 5, 2002 | 07:21 PM
vinay's Avatar
Whoops!!! I forgot to say that mine is a camaro, I thought It has only one filament per bulb so when I switch on to high bean all the 4 head lamps are working so it says the filament is fine with the drivers side low-beam headlight!! So is there anyother thing like a circuit or cleaning the headlight switch or something?? Help Appreciated!!
Old Feb 6, 2002 | 10:58 AM
There are two filaments in the outer hi/low beam bulbs. One appears to be open circuit. Change out that bulb & it should work, again.
Old Feb 6, 2002 | 09:40 PM
vinay's Avatar
Thanks Tim!!!! I replaced the Head lamp and its just fine now!!
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
