Alternator problems after leaving light on
Old Feb 10, 2002 | 02:42 PM
kcassidy's Avatar
Last Friday I left an interior light on in my Camaro. I went out Sat. evening and had to get a jump before I left. The battery didn't seem to be charging as I drove because the radio & dash lights kept going out. I came home and charged it, and now the alt. guage reads 10.5 instead of the constant 13.5 I got before leaving the light on. Is this some strange coincidence, or did leaving the light on have something to do with my alternater not charging the battery as much as it did before? I haven't really taken it out since this happened, so I don't know if 10.5 is enough to keep my battery charged. Any ideas would be appreciated.
Thanks,
Kevin
Old Feb 10, 2002 | 04:30 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
Dead cell
After a battery has been drained it possibly could have killed a cell. It will still take a charge but sometimes not a full charge or not a charge at all. I would suggets you charge it and put a load test on it. I think Pep Boys or stores like that will test it for free. It do sound like you killed your battery. Thats where I would start. Also if you have a Volt meter I would see if your alt. is putting out 12 to 13.5 volts. You said your gauge is reading 10.5 volts. Double check with a VOM.If it is putting out 12 to 13.5 volts then it is your battery. If not hen it is your Alt.
Old Feb 10, 2002 | 04:34 PM
kcassidy's Avatar
Thanks i'll have to look into that.
Old Feb 10, 2002 | 04:37 PM
da BEAST's Avatar
Originally posted by kcassidy
but I didn't think that killing a battery could affect the alternator.
Kevin
A dead battery will not affect the alt. It just won't allow it to fully charge a dead battery
Old Feb 12, 2002 | 10:21 AM
mtccl's Avatar
A dead battery will burn out the diodes in the alternator. The alternator is not really designed to charge a dead battery....just to top it off after the short burst of start amps. Especially if the battery has a bad cell as mentioned. I would replace the battery immediately. If you mess around with this you will end up replacing the alternator too. Hope this helps? Good Luck!!
Old Feb 13, 2002 | 06:36 PM
kcassidy's Avatar
I'm going to get a new battery tonight. Hopefully it's not too late for the alternator! Thanks.
Old Feb 13, 2002 | 08:56 PM
da BEAST's Avatar
OK
You should be safe. I am willing to bet you are OK
Old Feb 13, 2002 | 09:00 PM
mtccl's Avatar
With the car running disconnect the ground wire on the battery. If the car dies then the alternator is gone.
Old Feb 15, 2002 | 04:50 PM
kcassidy's Avatar
It turned out to be the alternator. Thanks for the help guys.
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
