Battery Relocation
Old Feb 17, 2002 | 02:09 AM
AmorgetRS's Avatar
Battery Relocation
Hey, what is the correct gauge to use when you relocate the battery. I will be hook up some pretty serious stereo to it, but also am hoping to have a pretty serious engine.
I was looking at 1/0, any suggestions?
Old Feb 17, 2002 | 02:25 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
All you need is anything 4 or lower. But running thicker wire to the engine is only going to cause less resistance to the alternator and starter which don’t help that much. I assume the stereo amps are going to be in the back by the battery so you are going to hook the power straight up to the battery so the wire running up the engine from the battery is not going to be taking the load from your stereo.
Old Feb 17, 2002 | 02:31 AM
AmorgetRS's Avatar
Well, I thought about it, and here is kinda the setup I was thinking. 0/1 from the battery for like 5 feet or so, to a distribution block, then 2 or 4 gauge running off to the front of the car, and 8 gauge or maybe 4 running to my amps.
Would that work well enough? Do I need to worry about the current running through the distribution block?
Old Feb 17, 2002 | 02:35 PM
rhuarc30's Avatar
Before you get started do you race this car on the track? NHRA regs require a current shut off switch when you move the battery to the rear of the car. If your not worried about that then what your talking about sounds good. Just remember that the bigger the guage you can run the less resistance, which is good for pretty much everything. You may want to consider putting remote jumper terminals under the hood to allow jump starting and/or charging from either end of the car, and they can also function as a junction for any electrical accessorys you add up front.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
