wire from engine bay running under the car?
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
i had the maro jacked up the other day and i noticed this wire running under the car.. it looked like it was a green and a tan wire and the green wire was cut.. it hangs down lower than the car.. what does these woires do?!? are they important?
mike (loomdog)
mike (loomdog)
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Under which section of the car? Engine bay? Tranny area? Rear?
Tan and green run the headlights; tan goes to the oil pressure sending unit; green to the temp sending unit; green to the horn(s); green and blue to the backup switch on a manual tranny...
Pete
Pete
Car: 82 Camaro Z28
as best as i can tell it runs from the engine compartment to the rear end.. kinda following the driveline.. backup switch on manual tranny sounds like the closest thing it could be, except i have an automatic tranny.. oh well.. ill evenually find out what it does..
mike (loomdog)
mike (loomdog)
Car: 89 GTA, 09 G6, 03 E250
Engine: TPI 350...Soon to be a 383
Axle/Gears: Borg Warner
Could it be a manual switch for the fuel pump? I just bought an 89' bird, w/ a viper alarm (what a joke) and it had something like you described.
AkDrifted
Aug 17, 2015 07:45 PM
