Bolting ground strap on coil bracket? Electronic Interference possible?
Old Mar 3, 2002 | 04:17 PM
Night Hawk's Avatar
You know the ground strap that comes off the firewall and bolts on to the engine block?
I can't reach or even see where it bolts to the block, but I see that I can bolt the strap to the metal bracket that holds the external ignition coil. Is this an ok spot to bolt the strap too? It seems like a fair size metal bracket.
By bolting the ground wire by the coil, will it create electronic interference with the coil or have any ill effects at all?
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Fast355
Dec 2, 2016 06:33 PM
