steerin colum
Old Mar 5, 2002 | 11:48 PM
84,86,88Z28's Avatar
steerin colum
i want to put in my other steering colum,the problem is,the one i have now has cruise,which i dont want anyways,the other doesnt,but has delay whipers,will the harness still work,or will i have to switch them or what?my friend said alot of camaros,came with the options already wired up,with the wires right there,is this true?or basically how much of a pain in the a$$ will it be?thanks for your time.
Old Mar 6, 2002 | 04:19 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If the new column doesn't have cruise then you don't really need to worry about that. If you don't have delay wipers already, you'll have to grab the motor/assembly from a car that does have it. Other than that, there's no special wiring needed for the delay wipers. My camaro didn't have delay wipers & I swapped to a column that had it (didn't know at 1st, no turn lever) but, I did a seach & a few other people said you just have to get the right motor/assembly & plug it in & it'll work. I got one for $5 at the junkyard, plugged it in & it works fine (so far).
Old Mar 6, 2002 | 05:35 PM
2vmodular's Avatar
you can use a delay wiper switch with a non-delay wiper motor. both high and low speeds will work fine, washer pump will work as well.
the only quirk will be that the wipers will immediatetly stop in the middle of the windsheild if you move the selector lever to the delay section of the wiper switch.
to get the intermittent function working, you'll need a wiper control module from a pulse wiper equipped car. module is black and bolts to the front of wiper motor in the engine bay. wiper motor itself is the same regardless of whether car has pulse wipers or not, just the cover is different.
Old Mar 6, 2002 | 05:37 PM
2vmodular's Avatar
While on the topic of wipers, here's some pulse wiper retrofit notes:
I added intermittent wipers to both of the birds, none had the feature at purchase time. Swapped out the wiper switch in the column, added a new turn signal stalk, and changed out the wiper control board. The wiper harness and motor are the same regardless of vehicle trim level.
Can swap wiper boards among a decent number of general motors products. For instance one board i used for the swap is from a monte carlo and the other from a celebrity.
Old Mar 6, 2002 | 09:03 PM
deadbird's Avatar
Engine: TPI 305/ v6
On my camaro it was on or off.. no hi, no stopping in the middle of the windshield, either way it goes, you're going to need a motors/assembly from a car that had delay originally
DMSBRASILEIRO
Jun 11, 2004 04:29 PM
700r4=junk
Feb 14, 2004 06:27 PM
700r4=junk
Feb 6, 2004 04:34 PM
beamar
Oct 16, 2002 02:44 PM
86IROCTHD
Feb 19, 2002 06:08 PM
