VSS Help
Old Mar 19, 2002 | 12:22 PM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
VSS Help
My speedometer/odometer hasn't been working for a while now, so i'm trying to trouble shoot the problem. I have a 92 RS with the 3.1 V6 and as i understand it there is just the vss at the transmission, the ECM, or the speedometer itself that could be causing the problem. I think that the VSS buffer for this year/model is part of the ECM so if thats the problem its staying broken. Does anyone know of a way to test the VSS while its on the vehicle to test if its working? Does it send some kind of electrical signal that i might be able to test with a multimeter? Also, because i'm clueless here where is the vss located on the tranny? any help would be appreciated.
Old Mar 21, 2002 | 08:28 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
VSS on the tranny is located where the cable would of been. Look for an electrical connection back on the tailhousing ont he drivers side.
HTH
Old Mar 24, 2002 | 10:08 PM
Swapmaster's Avatar
If the speedo and odometer are both on the blink then you need
to replace the VSS on the tranny.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
