Battery Drain
Old Mar 24, 2002 | 10:19 PM
DSouthern's Avatar
Battery Drain
I have a battery drain (.74 - 1.10) amperes that I have insulated to the 20 ampere fuse in the engine bay near the battery.
I know this fuse provides power to the ECM, fuel pump, mass air flow relay, and burnoff relay.
I have unplugged the wires at the relays I could locate in the engine bay and this had no effect to reduce the current draw.
The other strange thing is that if I pull this 20 ampere fuse and plug it back in, the ampere draw starts at 1.10 and slowly goes down to .74, but stays at .74
What can I do next to continue trouble shooting this problem.
I have already searched this message board for "battery drain" problems, but none of them provided the help I need to solve my problem. Would appreciate any help you can provide.
Old Mar 24, 2002 | 10:22 PM
DSouthern's Avatar
After reading this message I see a typo in the first sentence.
I have isolated the problem, not insulated the problem. Just wanted to clarify.
Old Mar 25, 2002 | 12:48 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may edit your posts by clicking on the "edit" button in the lower RH corner.
Try disconnecting the ECM & see if the curent drain goes away. If so, it may be a faulty ECM.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
