Removed ECM. Will elec fan still work??
Old Mar 20, 2002 | 09:46 PM
ThirdGen Stoner's Avatar
I was wondering if it would or if it came out with the ECM harness in my 86 Z-28. And if it did come out. How would I go about rewiring one?
Old Mar 21, 2002 | 10:54 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Nope; won't work any more. ECM controls the fan. If you have dual fans, the secondary fan will still come on at the very high temp, but that's it. You'll want a relay and a cooler fan switch.
Old Mar 21, 2002 | 10:56 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
another thing im worried about are gauges, you could just run a ign wire from fuse panel to the relay for the fan on the firewall so it will come on with ign, thats what I would do anyways, put inline fuse of 20 or 25 amps on it too
good luck
Old Mar 21, 2002 | 02:21 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If your '86 Z was carbed (LG4 vin H, or L69 vin G), then the fan is not controlled by the computer - it was controlled by the A/C selector switch and a temperature switch in the RH cyl head, but if it was a TPI LB9, then the ECM controlled the fan & you will need to install a variable or fixed temperature fan control switch (available from Pep Boys, or other local auto parts stores).
Old Mar 21, 2002 | 03:15 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Good point, Tim. I wasn't even considering the fact that they made carb'ed Zs back then. DOH!
Old Mar 21, 2002 | 06:09 PM
Yes, it is a LG4 vin H. So it will still work?
Old Mar 22, 2002 | 10:55 AM
If you kept fan temperature switch in the RH cyl head, and the fan relay, then it will function as it did previously. As I indicated above, turning on the A/C switch will also turn the fan on.
Old Mar 22, 2002 | 03:51 PM
Ok. Thanks a lot!:rockon: Was starting to worry about that one...
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
