how to wire alternator,tack
Old Mar 27, 2002 | 06:41 PM
phillip kelly's Avatar
i have just taken out my v6 out of a 88 firebird and replaced it whith a 305 i have a hoy carb and a accell dist. cant figur out how to wire my tach and also my alt. my alt is a two wire were as my old one was a three wire help please
Old Mar 27, 2002 | 08:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Assuming you have a coil-in-cap dist, the TACH lead should be labeled on it. It will hook up to the white whire that was originally on the coil. If you haven't changed the Tach to a v-8 one, it will read high too. If your not sure where the white wire disappeared to, it goes (leads) to the bulkhead connector (firewall, next to the brake booster).
If you tell wire colors, most of what you need for wiring is here
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
