Trick Flow Heads
Old 07-22-2006, 12:37 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Trick Flow Heads
Trick Flow Kenny Duttweiler 23 Degree Heads, Assembled. TFS-30400003.
Less than 1000miles on them. Pocket ported and bowl blended. 2.02/1.6 valves, guidplates, screw in studs, dual springs good to .600lift. They are ready to be bolted right on.
A356-T61 aluminum
Combustion Chamber Volume:
62cc
Intake Port Volume:
195cc
Intake Port Dimensions:
1.28" x 2.09"
Intake Port Location:
Stock
Intake Valve Diameter:
2.02"
Intake Valve Angle:
23°
Intake Valve Seat:
Tungsten alloy
Intake Valve Length:
4.96"
Intake Valve Stem Diameter:
11/32"
Exhaust Port Volume:
72cc
Exhaust Port Dimensions:
1.35" x 1.5"
Exhaust Port Location:
Stock
Exhaust Valve Diameter:
1.60"
Exhaust Valve Angle:
23°
Exhaust Valve Seat:
Tungsten alloy
Exhaust Valve Length:
4.98"
Exhaust Valve Stem Diameter:
11/32"
Valve Guide Material:
Bronze alloy, intake
Bronze alloy, exhaust
Valve Guide Length:
2.0" intake, 2.25" exhaust
Valve Guide Clearance:
.0012" intake, .0016" exhaust
Valve Guide Spacing:
1.910"
Valve Seals:
Viton, .500" i.d. x .700" o.d. x 11/32" stem
Valve Seat Angles:
37° x 45° x 52°
Valve Spring Pocket Diameter:
1.615" for valve springs with spring cups
1.500" for two center valve springs using locators
Valve Spring Cups:
1.48" x 1.61" x .060"
Valve Spring I.D. Locators:
Used on two center valve springs for bolt clearance
Valve Spring Retainers:
7° x 1.25" o.d. chromemoly steel
7° x 1.437"-1.50" o.d. chromemoly steel
Valve Stem Locks:
7° stamped steel
7° + .050" machined steel
Valve Springs:
1.460" o.d. double with damper
125 lbs. @ 1.780" installed height
376 lbs. @ 1.180" open
420 lbs. per inch rate
.600" maximum valve lift
Pushrod Length:
Refer to instructions for recommendations
Guideplates:
For use with 5/16" pushrods
Rocker Arm Studs:
ARP 3/8"-24NF x 7/16"-14NC x 1.895"
Rocker Arm Type:
Stud mount roller rocker arms recommended
Weight:
22 lbs. each, bare
$775 plus shipping. PM me your town and zip for shipping quotes. I will allow pick up. Youngstown,Ohio-near the PA border
Old 07-22-2006, 04:59 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
PM Sent
Old 07-24-2006, 01:48 PM
Shake Zula's Avatar
ttt
Old 07-24-2006, 08:53 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Aluminum Heads`
Do you still have the heads? If so, I can pick up this weekend.
Thanks,
Josh
Old 07-25-2006, 08:34 AM
Shake Zula's Avatar
Still got them, and I dont know why. Its not often a good set of Trick Flows show up on the used parts market.
Old 07-26-2006, 03:19 PM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
Why are you selling them? Did you have them on a 305?
Old 07-26-2006, 06:15 PM
Shake Zula's Avatar
I need money!!!! They were first on a 388, then a 350. Now there on my back porch
Old 07-28-2006, 03:18 PM
Shake Zula's Avatar
ok, are there any serious buyers out there? or is everyone all talk?
Old 07-29-2006, 08:27 AM
Shake Zula's Avatar
How about $800 shipped? (continental US)
Old 08-02-2006, 02:49 PM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
sent you a PM
Old 08-04-2006, 05:23 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Trick Flow heads....
Wow, I thought these would be gone quick! I'm a buyer if I can squeeze in on the list. R U set up with Paypal? Or how do you want the funds???
Nitro
Old 08-05-2006, 12:53 PM
Shake Zula's Avatar
Money Order or Cashiers Check. Havnt had any serious buyers yet. Just a lot of people who want them for the same price as Vortec heads
Old 08-11-2006, 09:54 PM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
sent you a pm
Old 08-12-2006, 05:12 AM
Black89Vette's Avatar
Any flow numbers available on these heads?
I am interested.
Old 08-30-2006, 11:31 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
sent you a pm i would like to buy these heads
Old 08-31-2006, 09:11 AM
wrenchman1213's Avatar
Car: 1986 Z28
Engine: 406
Transmission: TH350
Axle/Gears: 9-inch w/ 3.50 posi
Heads
U still have these im really interested and will have the money this wkend. Shipping qoute ti 63841. THANKS
gta90
09-15-2015 04:00 PM
Mickeyruder
09-02-2015 02:45 PM
Ducati900ss
09-02-2015 09:05 AM
theurge
08-21-2015 12:46 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Trick Flow Heads
