Engine Parts
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Engine Parts
I have the following parts for sale
16 hydraulic flat tappet lifters $BO
Complete serpintine belt assembly with brackets and pulleys $100 obo
Complete v-belt pulley system brackets and pulleys $60 obo
mechanical fuel pump with 200 km on it $35 obo
Melling high volume oil pump $25 obo
Complete 95z28 air box assembly $75
Holley fuel pressure regulator $15
Stock oil pan for 2 piece rear main seal block $BO
ARP Stainless intake bolts $BO
New Eagle cast stell crank $150
Used stock 2 piece rear main seal crank $BO
88 TBI ecm $BO
Computer controlled distributor with remote mount coil $ 30 obo
New Hypertech 160 degree powerstat $BO
Brand new egr valve that I bought for my 88 tbi but never installed. $BO
Energy Suspension Poly A-arm bushings $BO
Brand new B&M recalibration kit $BO
3/8 Rocker arm poly locks $BO
88 TBI ecm $BO
The distributor is in excellent shape I replaced the cap and rotor about 500 km before I swithched to a carb set-up.
and if the ignition module is the coil then yes it is included.
Let me know if interested.
Thanks, Josh
Thanks, Josh
Car: '01 Vette 'vert
Engine: Ls1
Transmission: 6sp
The ignition module is the thing inside the distributor, under the rotor, that has some wires going into it. How's $40 shipped? Can send paypal tomorrow.
wat's your zip and I will get a shipping quote.
i can't se it being more then 10 dollars so 40 shipped proballly is okay but let me look into it.
And yes it has the module. I literally pulled it right out of my car qand put it into the box.
Woked excellent.
Get back to me with your zip and we can go from there.
Thanks, Josh
Woked excellent.
Thanks, Josh
what is the info on the regulator? solarofthesix@hotmail.com
Regulator is adjustable from 4 1/2 to 9 psi.
Part number HLY-12803
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
whats the stroke on the eagle crank, also is it for 350 or 400 mains, 2 or 1 piece rear main seal? thanks
Brandon
Brandon
ttt
I need this stuff gone so shoot me a reasonable offer.
