7730 ECM and harness from 91 305 tpi
Car: 1991 Z28
Engine: 408 LSX
Transmission: Pro-shifted T-56
Axle/Gears: 9"
1 '7730 ecm from 1991 305 tpi automatic transmission Z28 car
1 hypertech chip adapter
1 BURN1 flash'n'burn usb based chip programmer
2 C1 Atmel at29c256 chips
1 ecm harness from a 1991 305 tpi automatic transmission Z28 car
1 working dual plug gm coil and bracket
1 Distributor, small cap hei from this application, 91 z28 305 tpi, came off running engine, no cap.
paid over $100 for new chips and burner, you get everything i have for $150 shipped anywhere in the 48 states. Any offers you have I'd be happy to listen to (i am swapping to an LSX style motor), and any questions you have i'd be happy to try and answer.
Thanks for your time,
Robbie Kellerhals
423-314-4901-cell
Robbie Kellerhals
423-314-4901-cell
Car: 87 vette gettin parts for 3rd gen
Engine: 350 w/ ZZ9 inside.
Transmission: 700R w/ kit
I am very interested in this set up. Do I need anything else to get my TPI intake up and running other than what you have? May sound silly, but just want to make sure.
Thanks.
Michael
Only 6 days till that planes gets me out of this hot dusty Kuwait desert, and back to the good ole USA.... wooohhoooooooo ! ! ! ! !
Thanks.
Michael
Car: 1991 Z28
Engine: 408 LSX
Axle/Gears: 9"
mkstewet1 as long as you have all the sensors needed for this setup you should be good to go, i do want to warn everyone that i did separate the ecm harness and the harness that comes out of the fuse box, so you will probably be able to use the existing harness that is in the car, I strongly reccomend a haynes manual or some other source of detailed wiring diagram. i marked every wire i had to cut, so with a good diagram you should be fine. also the harness for the a/c and heater isn't included. ALso if im reading this correctly, it reads as if your serving your country, if this is true then first i want to thank you very much for that.
midniteplowboyy read above, you will be the first in line if mkstewet1 doesn't buy this lot of goodies, Sorry no datalog cable, (i used a friends) and I do not accept paypal, I can post pictures, i just have to line up a good camera.
Thanks to both of you for looking
Car: 1991 Z28
Engine: 408 LSX
Axle/Gears: 9"
Now included, working dual plug gm coil and bracket! same price.
Car: 1991 Z28
Engine: 408 LSX
Axle/Gears: 9"
Sooner or later i'll add everything i need to sell,
Distributor, small cap hei from this application, 91 z28 305 tpi, came off running engine, no cap. $35 shipped
Have you heard from mkstewet1? I'll take your package deal with the distributor and coil, if he backed out. Do you have a knock sensor also. What else you got I might need?
Thanks,
Thanks,
Sanjay
Aug 12, 2015 03:41 PM
