SBC 2-piece Flywheel Brand New
Old Nov 10, 2006 | 08:42 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Billet steel, 153 teeth, 2-piece rear main seal. The weight is between 20-25lbs not sure specifically. Never been installed. I can't use it because my engine is a 1-piece rms.
$120 obo.
PM me for any questions.
Thanks.
Attached Thumbnails SBC 2-piece Flywheel Brand New-flywheel1.jpg   SBC 2-piece Flywheel Brand New-flywheel2.jpg
Old Nov 13, 2006 | 12:41 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Do you have the part number? I am doing an LT1 T56 swap and could use a flywheel if it is the right one.
Old Nov 15, 2006 | 08:03 AM
Car: 1986 Iroc
Engine: Afr 408
I'll have to check if there is one on the flywheel itself, I threw away the box. Is your engine a 2-piece rear main seal?
Old Nov 15, 2006 | 09:51 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Yea it is a 406, 2 piece rear main. From what I have read and seen the LT1 6 speed needs a flywheel that is thicker or spaced a little different for the pull clutch setup.
Old Nov 21, 2006 | 12:45 PM
Car: 1986 Iroc
Engine: Afr 408
Anyone need a flywheel?
Old Nov 22, 2006 | 12:57 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
I am still interested if it fits.
Old Nov 27, 2006 | 08:25 AM
Car: 1986 Iroc
Engine: Afr 408
Do you want me to pull some dimensions off it? I have no idea if it would work on a T56 setup.
Old Dec 2, 2006 | 10:37 AM
Car: 1986 Iroc
Engine: Afr 408
$110 obo
Old Dec 11, 2006 | 08:51 AM
Car: 1986 Iroc
Engine: Afr 408
Make an offer
Old Feb 18, 2008 | 10:34 AM
partsbin321's Avatar
Car: 1987 Iroc
Engine: 502
Axle/Gears: Ford 9" 3.73
Re: SBC 2-piece Flywheel Brand New
Originally Posted by Thomas Aquinas
$110 obo
Do you still have this flywheel? I need a two piece rear main seal flywheel.
Loudnproud86
Jul 14, 2016 12:59 AM
Stangski09
Nov 14, 2015 01:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
