FS/FT TPI wet nitrous kit w/ purge . window switch and digital pressure guage
Old Dec 7, 2006 | 09:45 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
i have for sale the NOS brand tpi wet plate nitrous kit, PN 5151, comes with solenoids with mounting brackets, lines, spray plate, jets for 50-150 shot, relay, WOT switch with custom mounting bracket, longer tb bolts, purge, 10lb bottle, and fuel pressure safety switch $400+ shipping SOLD! or should i say traded!
MSD digital window switch jegs PN 121-8969 $89.99... $75 shipped
dynotune digital pressure guage (black with red LED numbers) with sending unit and -4AN adapter $170.00 new for the two $125 shipped
buy the guage and the window switch together for $170 shipped!
Old Dec 7, 2006 | 10:02 AM
theopsmanager's Avatar
I have a superpower shot carb plate setup new in the box that I could possibly trade. I have a guy who I am supposed to be doing some trading with this weekend. But if it falls through would you be interested?
Old Dec 7, 2006 | 10:15 AM
Car: 91 z28
yes sir! id rather trade straight up for what i need instead of selling my stuff and then buying others, makes it real simple,
EDIT: Does it have a purge? just wondering because the one thats with this kit is already attached to the N20 solenoid and i dont want to pull it apart, if not thats no biggie
Old Dec 7, 2006 | 10:36 AM
I have a new Zex dual purge kit with my setup. I will email you sat or sunday and let you know whats up with the other guy that I am supposed to be trading. can you send me some pics of your setup and I will do the same for you. My email is theopsmanager@bellsouth.net
Old Dec 7, 2006 | 10:52 AM
Car: 91 z28
yep, its off the car right now but i can get them to you asap heres a quick pic of the bracket i made that you'll be getting
Old Dec 7, 2006 | 02:26 PM
How long have you ran this setup and what size shot are you using. I am running the cone shaped K&N filter. Will I be able to tap into it or am I going to have use the snorkel setup again?
Old Dec 7, 2006 | 02:32 PM
Car: 91 z28
that pic is of a different nitrous set up, the one you're getting is the actual spray plate that goes between TB and the plenum, you'll see in the pics
Old Dec 10, 2006 | 01:53 PM
Car: 91 z28
pics added!
Old Dec 10, 2006 | 09:45 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
this is kind of off topic but i see your specs under your name what did your 305tpi run with the 100 shot and was it a stock motor? what gear were you running also?
Old Dec 10, 2006 | 10:04 PM
Car: 91 z28
i never been to the track with the nitrous, i only goofed around on it in the streets, its only 2.73 geared, but my guess is 13's would be attainable with good tires and a little weight reductions, some gears would make a world of difference
Old Dec 11, 2006 | 03:24 PM
Car: 91 z28
BUMP new price! 500 shipped for everything!
Old Dec 12, 2006 | 11:19 AM
Car: 91 z28
kit's sold! pressure guage and window switch still for sale, buy em both for $170 shipped! or make me an offer!
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Dragonsys
Sep 25, 2015 03:51 PM
