STROKER W/TRANSMISSION
I'VE GOT A 383 Pump Gas Stroker:
Aftermarket Cast crank, Scat H-beam rods, Wiseco Forged FT Pistions, Predator Hyd.Roller cam(229/234, .561/.576, 112LSA). TFS G1 heads w/1.6RR and RPM Airgap manifold. Manifold to Pan.
Built 700R4 w/3200 stall lock-up ACC converter.
The motor and tran are in excellent shape. The whole set-up has has only one season on it.
This combo ran 12.40's on Drag Radials in my 3650Lb '83 T/A with full exhaust. Lifted the front end off the ground leaving(1.60's @ 60ft). Surprise your friends at the stoplight.
Runs great but I'm gettin' serious. Sticking in my 422CI Stroker with a TH350.
Asking $3600.
Asking $3600.
Also have a couple of other motors:
NEW never been fired. Poor Boy stroker. 383 balanced with TRW Hypereutectics, new Cast crank, short rods w/high strenght bolts, FT Solid 248/252 @ .05 .532/.540", 106LSA, roller tipped rockers, Vortec heads with good springs and screw-in studs. Professionally assembled. $2000
New Crosswind Manifold available for an extra $125.
New 408CI short block with XE274 hydraulic cam. Fully balanced w/Dished 12.5cc Hypereutectic pistons, PF rods, Scat9000 crank, flexplate/dampner. Prof. assmbled. $1300
Whole top-end for the above shortblock. Topline Vortec heads; Pocket Ported Flow 258/187cfm @ .500", can provide full set of fow #'s, 2.02/1.6" Valves. Screw-in studs, 1.43" spring pockets, New 1.6 Guided RR., Comp Beehive springs. Used Victor Vortec manifold. $800
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Where are you? I'm interested in the 408 if it's close to Iowa. What block is it - 509?? What's the deck height / piston deck clearance?
I'm located in Southern Oklahoma.
Don't know the block # but will find out for you.
The deck ht/piston distance is std.(>.025"). I have a set of Cometic MLS Gaskets that are .027" thickness and was going to mount the heads with these to get a deck ht to psiton distance of .042". The gaskets are expesnive as H*** but if someone buys the motor w/heads I'd throw them in at a serious discount.
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
can you pm me with all the details about this shortblock... have a problem with mine and this looks like it might be the way out i need.
thanks
thanks
Math is a little off on the compressed height. 0.025+0.027 = .052" Just so whoever buys it doesn't get upset.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
if you do split it i might want the tc.
This stuff's got to go.
Found some additional parts:
SBC 1.6RR from CAT. New never been out of the box. $120
New Speedpro Hyd. Roller cam for 86 and newer roller block. 230/230 @ .05, Lift-.480". Great cam with a set of Vortec heads. $100
New Crane Retrofit Hyd.Roller. 214/222, .488/.509" 112lsa #HR-276-2s-12 IG.
great streetable cam. Makes power to 5500. Good with Nitrous. $150
New Comp Hyd. Small Base circle for stroker. 239/239, .480",112lsa, PN12-000-5. $100
Holley Spreadbore w/Mech sec., Rebuilt by the Carb shop but has never seen gas. Swap out that old Quadrajet. $225
Chevykid810
Sep 28, 2015 12:57 PM
