383 forged race motor, tko tranny
Fully running race motor. spared no expense... over 10k invested in the engine. Currently installed in '86 IROC so anyone interested can come see/hear it run.
This motor was originally built with the intention of running a 600+hp nitrous setup using only the best of parts. Machine work and assembly by RV Engines in Alexander NY. Have all receipts.
Engine:
383 .050 over. Originally a 2-bolt block drilled for splayed caps.
Fully balanced and blueprinted. All specs are documented.
ARP bolts throughout
AFR 195 76cc heads milled ".020 to attain 10.5:1 CR
Childs & Albert file fit rings for nitrous
Scat forged crank
Lunati Streetrace 6" rods
Ross Racing N20 pistons
Pro Race SFI balancer
Jomar rocker arm stud girdles
Comp 294S 248/248
Summit 1.65 roller rockers
Miloden splayed caps
Melling High volume oil pump
current set up:
port-matched Victor Jr intake
Race Demon 750
Holley HP fuel pump
MSD pro billet, coil, and 6AL
GS Motorsports vacuum evac
March Performance serp pulley setup
Tranny:
Tremec TKO 5 speed transmission
Centerforce Dual friction clutch and SFI flywheel
Tri-ax TKO shifter
At this point I'm looking for interest / reasonable offers.
May consider partial trades including a complete LS1/t56 setup
Engine:
Scat forged crank
Comp 294S 248/248
current set up:
Race Demon 750
Holley HP fuel pump
Tranny:
Tri-ax TKO shifter
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
this motor is nasty. the whole setup is. I wish i could buy it. TTT
thanks for the support Dan. I can't remember, did I start this thing up when you were here?
the tranny is a 3550
1st 2nd 3rd 4th 5th Rev
3.27 1.98 1.34 1.00 0.68 3.00
absolutely, but probably not before having high confidence that the motor will be sold.
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
LT1Formula
08-20-2015 09:36 PM
